codes off reader
<table class="MsoNormalTable" style="border-style: none; border-collapse: collapse; width: 452.5pt;" width="504" border="1" cellpadding="0" cellspacing="0"><tbody><tr style=""><td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0in 5.4pt; width: 35.7pt;" rowspan="2" width="41" valign="top">122
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 38.55pt;" width="48" valign="top">
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 37.8pt;" width="47" valign="top">
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 26.95pt;" width="36" valign="top">
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 513.5pt;" width="545" valign="top"> TPS circuit below minimum 0.6 volts.
</td> </tr> <tr style=""> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 38.55pt;" width="48" valign="top">
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 513.5pt;" width="545" valign="top"> TPS circuit has intermittently failed below minimum 0.6 volts.
</td></tr></tbody></table>
anyone know what that means?
also got code 212
<table class="MsoNormalTable" style="border-style: none; border-collapse: collapse; width: 452.5pt;" width="504" border="1" cellpadding="0" cellspacing="0"><tbody><tr style=""><td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0in 5.4pt; width: 35.7pt;" width="41" valign="top">212
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0in 5.4pt; width: 513.5pt;" width="545" valign="top"> Loss of IDM input to EEC or SPOUT circuit grounded.
anyone? this is like japanese to me
What I was told was that I have a voltage issue somewhere and it is affecting my timing, fuel pump, and guages. I wish I knew where to start on this one.
The 212 would be an open resister or wiring from the coil to the computer on 1993 and older trucks.
Also may the SPOUT was grounded but I do not think the engine would run if it was. But you could check by putting a timing light on #1 plug wire and unplugging the SPOUT Jumper (shorting bar) and plugging it back in and see if the timing mark moves. If it moves the SPOUT wire is OK.
On 1994-1997 trucks with OBD I it would be someone put the wrong color ICM in. Should be black and not gray.
Go here for more info:
Ford Fuel Injection Throttle Position Sensor (TPS)
