390 tapping BACK!!!!
Old Feb 5, 2003 | 10:21 AM
Lamo26's Avatar
Lamo26
Angry 390 tapping BACK!!!!
Okay, I posted a thread here about 3 weeks ago about a top end tapping that I couldn't track down. Well after 1 month, new waterpump, switch to an electric fuel pump, new lifters and a new cam, the top end tapping is STILL THERE!!! #8 lobe on the cam was flat and the lifter was pretty beat up so I thought that was the prob but.....NO! Can't hear the tapping under accelleration but very eveident as the motor idles down through 3000 to about 2000 RPM. It's a slack noise, just with maintenance throttle and deceleration. One of the push rods was bent pretty good. When we had the left head off, we took a good look at the pistons and they looked great. We bore scoped the right bank and all looked good. Oil pressure is a constant 60. Spun the oil pump with a drill and no noise and good pressure, constant. I'm really pulling what hair I have left, out on this one. Anyone have a clue or a similiar experience on this one? HELP!!!!
Thanks, Bob in Tillamook, Oregon
Old Feb 5, 2003 | 10:57 AM
William's Avatar
William
I am glad you got the camshaft and lifter business sorted out. That could have caused serious engine damage. Fe's are famous for tapping wrist pins. Try this, hook a timing light to any plug wire, run the engine and listen, if the light flashes in time with the noise it is valve train related if it knocks twice for every flash it is engine related (wrist pin). Next trick is find which cylinder is knocking and disable the spark to it. If the noise stops or changes significantly it is wrist pin or rod bearing. Wrist pin noise while annoying can be deferred until next overhaul.
William in Atlanta
Old Feb 5, 2003 | 11:35 AM
Lamo26's Avatar
Lamo26
Hey William- I'm sure you know how hard it is to "pin-point" a noise location but we have a pretty good consensus that the noise seems to be coming from #4 or 5. We pulled both and did'nt find any slop but that's not saying that we could have somewhere else. We are going to try your suggestion, sounds very reasonable. At the very least maybe we can narrow down the search. One guy on the forum said that he had a similiar tapping in his FE for 80k+ and nothing ever came of it! I don't know about you but I couldn't deal with that, I want the truck fixed. I know quite a few of the guys here are going to cringe when I say this but I drive my truck pretty infrequently and short miles at that, mostly to and from work. So there is most likely gonna be some condesation build-up in the block between use. I think that's the culprit which led to the demise of the cam. Also another tidbit, the noise started about a month before I tore into it, very soft, quiet but it got progressively worse quickly. I only drove it 4-5 times since the onset of the noise and then only 5-20 mile trips. Sorry bout the long post but the more info, the better chance I can get some remedy.
Old Feb 6, 2003 | 11:47 AM
Rat wagon's Avatar
Rat wagon
I have a 360 2v thats been ticking for 10 000plus miles,
16.2seconds @91mph, best way to deal with these
noises is get a good stereo, or some loud exhust
unless it affects performance...
Old Feb 6, 2003 | 02:55 PM
76_390FE's Avatar
76_390FE
Maybe you have already ruked this out...but it could be an exhaust leak up at the manifold
WarOzz
Oregon Chapter
Jul 18, 2010 11:09 PM
mikeeeep
1997 - 2003 F150
May 22, 2009 02:04 PM
1pump
18
Sep 11, 2007 11:55 PM
Idiomaticman
Offroad & 4x4
Feb 23, 2004 11:14 AM
edward327
Bronco II
Feb 20, 2004 05:25 PM
