Negative battery cable question
Old Jun 10, 2010 | 12:44 PM
DBGrif91's Avatar
DBGrif91
I've seen it on dozens of vehicles, but until yesterday when I was cleaning my connection, I never questioned it.
Why do they ground the negative battery cable to the block? I could be wrong, but doesn't the block ground to the frame thru the motor mounts? So why not just ground directly to the frame? Was it just not convenient?
I'm sure there's a reason for it, I'm just not sure why.
Old Jun 10, 2010 | 12:54 PM
jas88's Avatar
jas88
The motor mounts are typically isolated from the frame with rubber, this allows the motor to shake and torque without imparting the same amount of motion to the frame. They run the ground to the block because the starter is on the block and that is the biggest load the battery will typically see on a stock vehicle. There are redundant ground straps that go from the motor to the body or frame or both to complete the circuit for other items that ground to the body/frame.
Old Jun 10, 2010 | 01:03 PM
DBGrif91's Avatar
DBGrif91
Yeah there's rubber separating the mounts from direct contact w/ the frame, but don't the bolts holding the mounts to the frame create a connection between the two?
Old Jun 10, 2010 | 01:20 PM
jas88's Avatar
jas88
No, if they did then the rubber part would not do anything. Next time you are at a parts house, ask the counter guy if he will let you look at a new motor mount.
Old Jun 10, 2010 | 01:24 PM
lew52's Avatar
lew52
You can never have to many grounds , i use the stock ground , plus motor to fame , motor to fire wall , motor to intake ....Lew
Old Jun 10, 2010 | 04:38 PM
EPNCSU2006's Avatar
EPNCSU2006
The negative cable on my truck has a clamp and a stripped area mid-way between the engine and battery where it bolts to the frame.
Old Jun 10, 2010 | 04:58 PM
subford's Avatar
subford
If you do not pull a trailer you do not need the ground to the frame.
It is only there for the trailer an trucks without a rear bumper for the plate light.
The van (E series) do not even have the frame ground stripped area mid-way between the engine and battery.
Old Jun 10, 2010 | 05:16 PM
wickedklown83's Avatar
wickedklown83
not to be a smart a$$ but isnt that kinda pointless? your grounding the engine to itself ??? as said not trying to be smart, just asking
Old Jun 10, 2010 | 05:40 PM
Old93junk's Avatar
Old93junk
True statement........I had a 85 F-150 the owner "gave up on it" because of electrical problems..............2 new ground straps later, and I am enjoying the $600 the PO put into it in new parts..........cost to me, "come tow it off my property"
Old Jun 10, 2010 | 05:46 PM
lew52's Avatar
lew52
Yeah that could be over kill , but like i said , good grounds are very important , more so with a high performace engine & all the add ons , you would be suprised at what a week ground can do....Lew ....are you sure your not a smart *** LOL
Old Jun 10, 2010 | 05:50 PM
lew52's Avatar
lew52
...Yeah i have had some problems with grounds before & it wasn't the battary grounds , thats why i make sure everthing has a good ground ....
Old Jun 10, 2010 | 11:37 PM
poocher pup's Avatar
poocher pup
glow plugs put more drain on the battery than the starter does in a diesel and both my batteries ground to the block, but one also to the frame.
troverman
6.7L Power Stroke Diesel
15
Jan 18, 2017 06:44 PM
bkgeig
Dec 16, 2016 11:42 AM
Dean06919
Nov 15, 2016 03:06 PM
GM4WALLS
Mar 4, 2016 10:27 AM
Order and Chaos
Oct 24, 2015 04:45 AM
