Transfer Cases, The Basics
Old Jun 10, 2010 | 09:28 AM
greywynd's Avatar
greywynd
Okay guys, help me out on this one. I've drove 4wd lots over the years, but never wrenched on it. I know there were some different transfer cases in these trucks, but have no clue as to how to identify them, what sort of maintenance they require or anything like that.
I'm hoping we can put together a thread that tells what cases were used, how to identify them, what maintenance issues they have and require etc. I know some use gear lube, others use ATF for example. Would be great to get some pics in here too, and maybe we can even talk about basics of removal and installation etc.
So, tell us what you can about transfer cases!!
Old Jun 10, 2010 | 10:00 AM
oreocreaming's Avatar
oreocreaming
just a fluid change. fill and drain plugs are in the rear of the drop. other then that, if it aint broke, nothing else needs to be done. ATF btw
Old Jun 10, 2010 | 10:02 AM
oreocreaming
might as well do your tranny same time. changing them at the same time helps you keep track of services. transfer case doesnt need to be done more then the tranny.
Old Jun 10, 2010 | 11:59 AM
wreckinball's Avatar
wreckinball
Wow so where to begin. First:
Borg Warner 1345's and 1356's most common.
My Exp is with the 1356 as its in mine. in HERE is my album with all the parts and exploded views of both. includes most part numbers. To see the identification look below and left of the electric shift or the area where it would be if yours is manual(rear of case as it is installed), you will see the borg warner logo and then to the left of that is the number. The first four are the model.
Removal and reinstallation is a snap. Six bolts to pull it. The holding pin will keep it there so it is easy to put back in. It weighs a bit but nothing that you wont be able to handle. Has a paper gasket that is cheap from ford. Make sure you have a jack with a 2x4 frame to support it if you cant lift it. that will save you a lot of time with balance.
Fluid is ATF, Anything that has the dex/merc III/IV or equivalent. Not type F or the new stuff for the new trucks. capacities below:
NP 2-speed part-time - 6 to 6.5 pints
Borg Warner 13-45 Full-time - 6 to 6.5 pints
Borg Warner 13-56 manual and electronic shift - 2 US quarts
Borg Warner 13-56 with PTO - 6.1 US quarts
(not 100% but these should be damn close)
I have the entire re/re proceedure out of the book scan i got from Peter if anyone needs it, just pm me.
This just scratches the surface but you get the idea. I'll post links to sites tonight.
Old Jun 10, 2010 | 02:33 PM
powerstroker100's Avatar
powerstroker100
I think my xfer case is leaking very small drops of oil, it must be the seal near where that yoke connects to that ujoint on the front driveshaft, every morning I see one drop of oil right underneath it and find a little bit on the u joint
Old Jun 10, 2010 | 02:35 PM
powerstroker100
also the transfer case if only activated or having any use when 4x4 is activated? correct? so when Its in 2wd the xfer case serves no purpose? or does it? the rear driveshaft does not go into the transmission it goes into the xfer case, or so it seems?
Old Jun 10, 2010 | 03:26 PM
greywynd's Avatar
greywynd
Some of the basics I can help you with on that question, in 2high, power goes straight through the transfer case to the rear drive shaft at a 1:1 ratio. In 4 high, again, a 1:1 ratio, but both rear and front shafts are powered. In 4 low, there is a reduction, that then supplies both shafts, the reduction ration I don't know, and suspect it is different for different transfer cases.
Old Jun 10, 2010 | 03:58 PM
powerstroker100
thanks!
Old Jun 10, 2010 | 10:08 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Low range in a 1345 is 2.72 to 1
Low range in a 1356 is 2.79 to 1
Those two cases cover 96% of the diesels out there in our era.
Old Jun 10, 2010 | 10:30 PM
greywynd's Avatar
greywynd
Quick question, I know the tranny would have to be changed, but would swapping a 4wd tranny and transfer case (and rear driveshaft) into a 2wd truck cause any issues? I'm thinking of an intermediate step in a 2wd to 4wd conversion, and having the lower range would be nice for close quarters work and the like.
Old Jun 10, 2010 | 10:33 PM
peruses's Avatar
peruses
shouldn't cause any probblems, but 4x4 conversions can be a real pain the 4x4 frame and suspension are diferent
Old Jun 11, 2010 | 06:41 AM
mistakenID's Avatar
mistakenID
Hanging the transfer case would be the easy part and would be fine in a 2 wheel drive. It's sticking the front axle in where things can a bit tough on a full change over.
Old Jun 11, 2010 | 10:23 PM
greywynd's Avatar
greywynd
Thought of another question relating to these boxes.... I know the bellhousing bolt pattern is different for diesel versus gas, but I thinking/guessing that transfer cases would fit either gas or diesel trannies?
Old Jun 11, 2010 | 11:27 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Yup, TC's are the same.
-Enjoy
fh : )_~
Old Jun 12, 2010 | 06:06 AM
RCrawler's Avatar
RCrawler
1356 should be a 2.69 low range.
Jason
Todd Fuller
Mar 28, 2021 08:39 AM
bulletpruf
Mar 10, 2020 01:09 AM
flyingtexan
Dec 15, 2006 05:40 PM
mudding4life
Jul 28, 2006 05:19 PM
my74f250
Mar 6, 2002 08:33 PM
