390 help
Old Jun 9, 2010 | 08:12 PM
robm3308's Avatar
robm3308
390 help
Hi, I going to look at a few engines this weekend and I know you cant tell the difference between the 360 and the 390 by looking at the block or heads so my question is if I take off the oil pan and check the crank while Im there what should the code/ casting number on it be or start with? Would like to make sure this is a 390 before I get it as I already have a 360 I know the only differences is the crank rods and pistons mainly the bigger stroke at 3.78 if anyone has any easier ways of doing this please chime in Thanks for any help, Rob
Old Jun 9, 2010 | 09:59 PM
Rockstone's Avatar
Rockstone
A 360 crank will have 2T marked on it, and the 390 will have 2U. 360 stroke is 3.50".
Old Jun 10, 2010 | 12:13 AM
montana_highboy's Avatar
montana_highboy
2T - 2TA = 360
2U - 3U - 3UA = 390
Old Jun 11, 2010 | 08:58 AM
bamaf150's Avatar
bamaf150
Or you can pull a sparkplug and measure the stroke.
