MPG with and without trailer
Old Jun 9, 2010 | 04:23 PM
fordxl68's Avatar
fordxl68
I have a 09 scab,max tow pkg.Added LT tires on the rear and a set of Firestone airbags.I towed my 9500lb fifthwheel from Rochester to Lake Placid aprox. 280 miles each way. Truck got 10mpg. Then we went from Rochester to Virginia without the trailer aprox 360 miles each way. Truck got 18.7 on the way there,a/c off, avg. speed 70mph. On the way home a/c on at 70mph 18mpg.Very happy with both mpg
Old Jun 9, 2010 | 04:36 PM
shotgunz's Avatar
shotgunz
That's great!
Another satisfied Ford owner. Best selling for 33(?) years for a reason.
Old Jun 10, 2010 | 07:37 AM
stephen.osborne1's Avatar
stephen.osborne1
How fast were you going with the trailer? Seems like kinda low, though 9500 is pretty heavy. What kind of terrain is that? Hilly?
Old Jun 10, 2010 | 08:25 AM
osbornk's Avatar
osbornk
You should be very happy with the mileage. I've towed everything with everything for the last 40 years and if when you get double digit mileage towing anything that large, you are doing great. The fifth wheel also catches a lot of air.
Old Jun 10, 2010 | 09:24 AM
3putt's Avatar
3putt
I agree with Osbork...10 MPG pulling that weight is very good. I suspect you were traveling at a reasonably low speed. I get about 10 MPG pulling 4,000 pounds at 70 MPH on the innerstates so I think you are doing very good.
Old Jun 13, 2010 | 09:09 AM
fordxl68's Avatar
fordxl68
MPG
With the trailer first 157miles no steep inclines. all highway at 65mph.filled up and got 10mpg took 15.5 gallons. Next 138 miles a lot of hills and steep grades from Watertown to Lake Placid mostly 55-60 mph,filled up and put in 13.7 gallons. On the way back I got 9.9 on the hills, I pushed it a little harder up the hills. On the highway part I kept it between 60-65mph and got 10.2 mpg.Before this truck I had a 05 screw with max. tow package with a 8500lb. fifth wheel trailer. I ave. between 10-11mpg on trips. I guess the 1000lbs.makes a difference.
Old Jun 16, 2010 | 02:05 PM
goingnorth's Avatar
goingnorth
I only get 16 hwy with 3k miles on truck going 73mph. and get 8.5 towing 7k at 65mph. I hope mine will climb to those numbers. I do have BFG at's and that might rob some but they are the stock size.
fordxl68
2009 - 2014 F150
Aug 20, 2010 11:42 AM
fordxl68
2009 - 2014 F150
47
Sep 22, 2009 01:08 PM
SkySkiJason
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 5, 2009 07:20 PM
gip
Car/truck Buying Advice
Jan 15, 2006 08:09 PM
jonnygorgo
New York Chapter
Jul 22, 2003 07:39 PM
