1966 - 1977 Early Broncos
Floor shift automatic
Old Feb 5, 2003 | 01:16 AM
fordtrucksforever's Avatar
fordtrucksforever
I was on the computer playing with my brain and wondered why you dont see broncos use a floor shift for the automatic conversions. Something like an early mustang or the shorter straight up shifter from a Mustang II. The Bronco II floor shift might be possible also. It could be set back farther than the transfer case shifter to get around any clearance snags. Utilize the Bronco II floor shift assembly to use both stock shifters. Maybe even raised up in a fabricated box. Rig up a cable shift like a lot of the cars have been equipped, in case hard linkage is not feasible. What am I missing here. Its cold outside so I havent actually looked real close to see whats all in the way. Any takes?
Old Feb 5, 2003 | 06:07 AM
Chuck 6083's Avatar
Chuck 6083
From: Where they take the census by counting the appliances on the front porch and multiplying by five
Hey bud,
Mine has a B+M floor shifter conversion. It works great.
Although I am going to change the ****. Previous owner has installed a chrome "skull". Not my style.
These floor shifters are cable activated so you can just about mount it anywhere and anyway you'd like. Clearence isn't usually a problem.
Chuck
