WOT what should boost be?
Contrary to popular opinion, more boost doesn't necessarly translate in to more power.
For instance, when my tranny was going out, it happened during the winter where we were getting 20* weather. I noticed on my TFT, both analog and OBD-II readings, were showing quick raises in tranny temp. We are talking about from less then 100 to 160 degrees in 10 minutes, in 20* weather. It takes me about 20 min to get to 160 in 90* weather and that's with a tranny that runs hotter then stock as it is(due to how it's built). Bare in mind, 160*s isn't a temp worth worrying about in normal conditions, but it's how quickly it got to that temp given the ambient temp and other driving conditions(normal driving, no load). If I was relying on the TFT gauge in the cluster, I doubt it would have alerted me when an issue had developed until spring or summer time or until I was getting funky rpm movements.
Yes, if those gauges are in the red then a problem has come about(either a sender issue or a true mechanical issue). However, those gauges can read good and you still have problems. Just because those gauges aren't in the red, doesn't mean you don't have problems.
So my question is to you: If the stock gauges don't let you know everytime that a problem is/has occured, how can you say that they are accurate enough? To me, if it was accurate enough, it would be able to let you know when every time a problem is occuring(if the gauge and it's related components are in working order of course).
My direct clutch on my tranny was shot. I saw how burned it was. My cluster TFT gauge never moved past normal. That to me doesn't spell out "accurate enough", but that could just be me.
Agreed, that's why I said a problem HAS developed.
Can you tell me exactly at what temp does the 6.0 psd engine will have a catastrophic failure within a +/- 50* F tolerance?
quote]
Both my analog TFT gauge and my obd-II TFT gauge was showing that I was going from less then 100 to 160 degrees in 10 minutes in the dead of winter(20*). Now 160 degrees would not cause the stock gauge to move past normal. In fact, 160 degrees is not a dangerous temp to be at. It's the fact that it moved from less then 100* to 160* in 10 minutes in 20* weather.
I had a tranny guy take it apart and lo and behold the direct clutch was shot. Either that or the tranny guy showed me someone else's tranny and passed it off as mine.
It doesn't exactly have to hit an extreme temp in order for their to be a problem, it's how quickly it raises to temps giving the conditions that it's in. I rarely pull anything in the winter, I could have gone all winter and that stock gauge wouldn't have showed a thing. Most of my trips would be 14 miles round trip, at most during the winter.
As to your +/- 50* comment, that spread becomes increasing importent the closer you are to the threshold of too high of a temp. 1200 on EGTs no...however, a +50 degree spread at 1225, yea, that might cause some issues if it's prelonged. You can hit pretty hot EGTs with a stock program I might add as well, surprisingly enough. That can be applied to anything on the + end of the spectrum for any reading you want to take. It all depends on how close that temp. is to the threshold of too much.
However, like in my example, sometimes it's not how hot it is, but how quickly it gets hot(rather or not it get's too hot is another question).
If I didn't have the a/m gauges at all, I would have never caught that failure until I started hauling loads or until summer really hit(maybe, or I might have had to wait until it cascaded into even worse of a failure). Either way, I could have been in peak horse show season and I would have had to miss out on shows compared to having spotted the issue in the winter.
Your "accurate enough" gauge did not let me know me know an issue had developed. You don't have to hit those high temperatures in order to be having problems. Your hung up on that.
My cluster TFT gauge never, I repeat, never moved above normal at all. Yet, it still turned out I had a fried direct clutch. How do you believe that makes atleast the stock TFT gauge "accurate enough"?
Now, I would imagine that if I was hauling one of my ~16k horse loads during peak show season in the summer, I'm sure that it would have read in the red, but that would be one helluva time for it to tell me I had a problem. That wouldn't be good for me or the horses.
In all honesty, given my experience with the stock cluster gauge, we might as well just have an overheat light that comes on. That's just about as "accurate enough" as our stock TFT gauge.
Once again, it's not just at what extreme temp you finally hit, it's how quickly those temp raise. I think your just hung up on the bottom line issue of what's the final temp. You might be having issues and not be driving it long enough, hard enough, or whatever to get it to finally show up in the red. Just because it's not in the red, doesn't mean your not having issues.
Bottomline, to me anyway, is that gauges are to help you avoid catastrophic engine failure, not just tell you when you're there, which is about as good as the factory gauges are. Just letting you know you are there.
