04 Expedition running boards?
Old Jun 8, 2010 | 09:08 PM
milo673's Avatar
milo673
Is it possible to remove the running boards from an 04 Expedition?
Old Jun 9, 2010 | 04:49 PM
alloro's Avatar
alloro
The brackets are just bolted on. Remove the bolts and unplug the running board lights and you should be good to go.
Old Jun 9, 2010 | 09:27 PM
rptr00's Avatar
rptr00
I did this to my 04. you will see a lot more exposed frame too.
Old Jun 10, 2010 | 07:47 AM
alwaysfords41's Avatar
alwaysfords41
Is that lifted too, or just taller tires?
Old Jun 10, 2010 | 08:56 AM
rptr00's Avatar
rptr00
yes its lifted with the truxxx 3/2 spacer lift on 315 70 17 BFG A/T's. The rear tire is the stock 265 70 17.
Old Jun 10, 2010 | 10:17 AM
alloro's Avatar
alloro
Just curious as to why anyone would want to remove the running boards?
Old Jun 10, 2010 | 11:06 AM
rptr00's Avatar
rptr00
well in my case, they didnt fit after my lift with 35's. I had to trim them back to make it work since it would rub at full steering lock. I decided to remove them in favor of 3" nerf bars after the drivers side board was broken when I hit something in the road. Its just plastic attached to a metal plate and not very strong.
osric20
Apr 13, 2017 09:30 PM
gtmustang00
Jan 22, 2016 10:59 AM
builtfordtough13
Jun 25, 2008 09:10 PM
ugotkern
Aug 23, 2005 06:51 AM
