driving without front DS?
Old Jul 16, 2009 | 11:19 AM
bnovak's Avatar
bnovak
Can you drive without the front shaft or does the transfer case puke itself all over the place?
Going to replace my u-joints, but it's one of those things that I'd rather pull the front and see how bad the joints are before pulling the rear, and if it's really bad it's going right to 6 states driveline.
BTW - this also used to be a JEEP trick to get an extra MPG or 2 on long highway trips. I actually picked up 3 MPG from Portland to Moab on my last trip out there.
Old Jul 16, 2009 | 11:31 AM
alloro's Avatar
alloro
Take special note of post #6.
https://www.ford-trucks.com/forums/8...t-removal.html
Old Jul 16, 2009 | 11:39 AM
bnovak's Avatar
bnovak
Screw it - it's going to 6 states Thanks alloro
I'm guessing you are either in the NE or the Great lakes region since everything you post about you are b*tching about rust. I'll send you a pic of a NW rig so you can be jealous
Old Jul 16, 2009 | 03:36 PM
alloro's Avatar
alloro
Yes you could do that. Just like I can choose who I am willing to help around here.
Old Jun 7, 2010 | 09:57 AM
briangelc's Avatar
briangelc
well, can you leave the front driveshaft out? any problems for the Transfer case?
Old Jun 7, 2010 | 04:16 PM
bnovak's Avatar
bnovak
No, you can't. The transfer case leaks all over the place.
Old Jun 7, 2010 | 08:37 PM
alloro's Avatar
alloro
Why do you say that? The front of the TC has a bolted on flange, not a slide-in yoke like with the rear DS.
Old Jun 7, 2010 | 10:18 PM
bnovak's Avatar
bnovak
aww crap I forgot which end of the transfer case I was thinking of. Yeah, it's been a while since I thought about fixing the car!
Yes, alloro is right, the front DS is a bolt on.
It's the rear side that leaks all over the place and you need the plug for.
Old Jun 9, 2010 | 09:02 AM
briangelc's Avatar
briangelc
yes, but does removing the front DS cause any excess strain on the txfr case gears when the rear tires start to slip?
i do not fully understand how the 4WD system operates in this truck, so I would like to avoid creating some sort of imbalance in the system, and cause damage.
Old Jun 10, 2010 | 03:26 PM
Omahastro1's Avatar
Omahastro1
I would not drive without the front drive shaft installed, but if you had to, I would pull the fuse that controls the automatic 4 wheel drive. This way the front end will not get the signal from the speed sensors. This is also a good idea if you have a flat and you have either a new spare and old tires on the truck or the other way around old worn out spare, new tires on your truck. With different size tires even in the same size catagory on your truck the speed sensors for the front drive shaft versus the rear drive shaft will sense different speeds and kick in the automatic 4x4.
uofmgriz
Jul 10, 2009 11:34 AM
basfire
May 14, 2008 05:15 PM
brush wagon
1966 - 1977 Early Broncos
Apr 28, 2008 07:18 PM
BigSoundRacing
Offroad & 4x4
Apr 2, 2006 12:02 PM
jlong1974
Apr 9, 2004 03:15 PM
