Polyurathane bushings for OBS ford
I'm looking for a bushings kit for my 250 and all I can find is the bushings. I threw out the old spacers and bolts because they were shot and now I cant find them other than on lmc and its a pita to order it all separate. Anyone know where to get a kit?
Lmc should have another page with the kit of bushings. They do not come with bolts though. I have been having the same problem and just bought that and went to a local store that sells nothing but bolts and stuff and got the bolts and washers i needed. Be prepared to spend some $$$ b/c bolts are quite expensive and get at least grade 5 bolts. I recomend grade 8 though. hope this helps
If you are doing ANYTHING that deals with the suspension of your truck, DO NOT USE GRADE 5 BOLTS. USE GRADE 8 AT A MINIMUM!!! Your suspension deals with a literal ton of force as it goes throughout its cycle; it is holding up and letting your truck move around on top of it. This is your safety and life that we are talking about, don't put it in jeopardy by saving a couple bucks buying inadequate hardware.
mcali2
06-02-2016 06:19 PM
Mike2theMax
18
12-08-2013 12:52 PM
FordFETruck
06-25-2013 04:12 PM
Josh88Ford
06-05-2013 08:59 AM
