Expedition Electrical Coil
Old Jun 8, 2010 | 12:31 PM
xtmsports's Avatar
xtmsports
Hi Guys,
I have a 1998 Ford Expedition with the 5.4L engine.
I know one of the ignition coils is bad since I've had this issue in the past. However, in the past, I have been lucky enough that the coil was bad enough to send an error code to the code reader to tell me which coil was bad.
Recently, when the truck is running for a while and its hot outside, the bad coil will start to act up and cause the engine to misfire.
My question is how do I go about figuring which coil is bad? Do I have to just replace all 8 coils?
Old Jun 8, 2010 | 05:24 PM
alloro's Avatar
alloro
The next time it's acting up, with the engine running unplug the 2-wire connector going to each coil one at a time. When you find one that doesn't effect the engine when disconnected, you've found the one acting up. Keep in mind that every time you disconnect a connector a trouble code will be set. They should go away at the next ignition off to on cycle.
Be careful not to get yourself or your clothing caught in the fan or serpentine belt when doing this.
Old Jun 8, 2010 | 05:51 PM
xtmsports's Avatar
xtmsports
thanks for the advice, I will try it. When it does happen, its usuallly while i'm driving on the freeway and its hot in vegas with the ac on. Around 60 mph, i will let off on the gas and then give it a little gas and thats when the engine misfires.
Old Jun 8, 2010 | 06:57 PM
fordtech08's Avatar
fordtech08
you could find a code reader that shows mode 6
Old Jun 21, 2010 | 04:30 AM
roachslayer's Avatar
roachslayer
I have a coil boot that wont come out!
Cyl #1 came out fine, but #3 is stuck. And #3 is the one that is misfiring, so I currently suspect... arcing has melted the thing to the inside of the hole. Is this normal with "leaking" boots?
I've tried pulling on the boot pretty hard with pliers and it wont come up. Any ideas how to resolve this?
Old Jun 21, 2010 | 09:05 AM
alloro's Avatar
alloro
I would just try to slide a long thin screwdriver down there, tap it with a hammer and try to break the boot free from the sidewall. Once it's out, do your best to clean the rest of the sidewall so the new boot/coil doesn't get damaged.
Old Jun 21, 2010 | 12:25 PM
roachslayer
Good idea alloro! I got it loose, and apparently without damaging it. It seems it was not melted, but it was RUSTY. Hmmmm... more clues.
I've swapped coil & boot with a known good cylinder. I still get misfire on #3. So now given that there were signs of rust down there, and knowing its NOT the coils in my case... should I suspect bad plug, or bad injector?
I guess I am on to the next task: trying to determine which. Ideas welcome, but at this point, it appears its not longer a coil conversation for me.
Old Jun 21, 2010 | 03:45 PM
alloro's Avatar
alloro
Because of the rust I'd first swap out the plug and see what happens.
Maltman
Sep 12, 2013 12:24 PM
handell35
2004 - 2008 F150
Apr 29, 2013 02:37 PM
frankiethethumper
Mar 3, 2013 12:03 PM
ChrisCarter
2004 - 2008 F150
Jan 30, 2012 04:01 AM
xtmsports
Sep 10, 2010 06:05 PM
