'98 4 banger idle problem
Old Jun 8, 2010 | 10:36 AM
Lanny Sutton's Avatar
Lanny Sutton
Most times when stopping at a light, the engine will race to about 4000 RPM when the clutch is depressed and then it will slow down to normal.
Another problem is at times it will idle at 5-600 with a lope and other times it will idle as it should.
What are the chances these problems have the same cause and what could that be?
Thanks!!!!!!
Old Jun 8, 2010 | 12:48 PM
wtroger's Avatar
wtroger
First clean or replace the IAC valve. it is the usual suspect for your type of idle problems.
