Please help with my vibration
Old Jun 8, 2010 | 09:26 AM
mgraveman's Avatar
mgraveman
I have an intermittent problem while driving down the highway. The truck gets to vibrating at high speeds just like I'm going over the rumble strips on the side of the highway or have severely cupped tires. It will start at any speed over about 30 if I hit a little bump and will continue until I slow down a lot or hit another bump. It doesn't feel like it's coming through the steering wheel, but it's very noticeable and annoying.
Yesterday I went over a bridge with several expansion joints and it would start and stop every time I hit one of those, or when the pavement changes from concrete to asphalt. When it's not doing it it feels fine, no vobration at all.
It went away for a long time right after doing ball joints, but it's only been 5k miles and a month or two. I did ball joints, gave it an alignment, replaced the steering stabilizer, and replaced the u joints. I have rotated the tires too. The ball joints seemed to make a difference, but they are still good and brand new. I can't find any loose suspension parts and it's been in two shops also to be checked out for bad or loose parts. Nobody can find anything.
Old Jun 10, 2010 | 08:22 AM
mgraveman's Avatar
mgraveman
No guesses even?
Any help would be much appreciated!! I have been paying attention since my first post and it kind of feels like it's coming from the back end. I hear a noise back there over bumps, but the lug nuts are tight.
Old Jun 10, 2010 | 09:32 AM
jh818's Avatar
jh818
Are your tires balanced as well?
Are your tires load E tires and filled to the max? If so, it could make the bumps feel hard. If you're not towing, I would drop it down to what is on the door jam.
Old Jun 10, 2010 | 09:38 AM
mgraveman's Avatar
mgraveman
My tires are load range E and are filled to what is actually on the gas tank door. I dropped the pressure after I started having issues. I have rotated the tires. I do not think they are balanced well.
Old Jun 10, 2010 | 10:05 AM
gearloose1's Avatar
gearloose1
Mileage? Suspension mods?
Tire size? Details?
Start checking for worn engine mounts.
Old Jun 10, 2010 | 11:39 AM
mgraveman's Avatar
mgraveman
Tire size? Details?
120k miles - stock suspension. It could use a set of springs in the rear, but want to wait until I get this figured out before I complicate things. Tires are the stock 235/85R16.
I'll look for engine mounts but it really feels like it's unsprung weight that is moving.
Old Jun 11, 2010 | 12:16 AM
jh818's Avatar
jh818
Try getting all 4 wheels balanced. Shouldn't cost that much. That may be the answer. Good luck.
Old Jun 11, 2010 | 04:32 AM
Shepherd2's Avatar
Shepherd2
Vibration problems are really hard to figure out without a rt. Does the whole truck shake or do you just feel it in the floor? Have you checked the slip yoke? Check for shiny spots in the metal around all the nuts & bolts in the rear, that will tell you if something has been moving.
Old Jun 11, 2010 | 08:00 AM
mgraveman's Avatar
mgraveman
I can't tell if it's the whole truck or the floor. It's not in the steering wheel.
What's the slip yoke?
Old Jun 11, 2010 | 08:26 AM
JimPat's Avatar
JimPat
Google up "Road force balancing" and find one in your area. Really helped mine out after I had them balanced twice at the dealer (to no avail).
Also - had to get under the truck with one of my weapons lights to see into the front sway bar end-links. The bushings were all rotted out. Replaced them.
Old Jun 11, 2010 | 08:29 AM
mgraveman's Avatar
mgraveman
Mine didn't look bad but it has occured to me that this is a likely culprit.
Messing with it last night I was able to pull the rear drivers side tire towards me and make a noise. I'm not sure if I was just pulling the axle shaft out a little bit and this was normal, but I suppose I'll start messing around in there.
I have a friend with a lift and need to catch him at the shop to get it all the way in the air.
Old Jun 11, 2010 | 02:47 PM
Andy91st's Avatar
Andy91st
Because it happens intermittently, you may want to consider to install an USB/Internet camera under neath of the vehicle, point to the suspected area and connect to a notebook (In the cabin) and capture the bugger while it is in action. I leaned alot about the driveline and the suspension in action with the camera mounted underneath. If it is a true physical vibration, you should see it in action.
Old Jun 11, 2010 | 03:12 PM
Shepherd2's Avatar
Shepherd2
Probably cheaper to just strap the wife to a creeper and go for a road test.
Old Jun 11, 2010 | 03:18 PM
mgraveman's Avatar
mgraveman
Divorce is cheap?
Old Jun 11, 2010 | 06:08 PM
UrbanXX's Avatar
UrbanXX
Look at the rear of the transmission and see if the viberation damper is there or missing. Also check the rear transmission mount.
The viberation damper on the transmission is a kinda steel L shaped damper.
My guess its loose or missing.
