Return line caps update
Old Jun 13, 2010 | 01:35 AM
  #46
oreocreaming's Avatar
oreocreaming
how about some after pics of the carnage? im dying to see how bad he killed them
Old Jun 13, 2010 | 09:42 AM
  #47
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I as well would like to see the carnage.
-Enjoy
fh : )_~
Old Jun 13, 2010 | 10:20 AM
  #48
mechelement's Avatar
mechelement
For your viewing pleasure:
You get the idea.
Old Jun 13, 2010 | 11:19 AM
  #49
tbone91's Avatar
tbone91
Well, at least it stuck...
Bummer.
Old Jun 13, 2010 | 06:41 PM
  #50
oreocreaming
wow, that guy is terrible. he would have been better off not using any fill material. i bet he could have taken care of that without the fill rod, just used the aluminum that was there.
Old Jun 13, 2010 | 08:25 PM
  #51
rhkcommander959's Avatar
rhkcommander959
Might be able to tap it and use barbs?
Pro welding there sry man i was looking forward to this as I liked the looks of them
Old Jun 13, 2010 | 08:49 PM
  #52
mechelement
New caps are in the works. We'll see what material they are and how they turn out. They're either going to be aluminum again or brass. This time I'll receive them welded, brazed or soldered.
Old Jun 13, 2010 | 09:21 PM
  #53
rhkcommander959
Let me know how well they work then, I'd love to try them if they hold up betetr than the olives
Old Jun 13, 2010 | 10:39 PM
  #54
Festus Hagen
Methanoholic
I see several issues that caused his problem ...
Coolant/Cutting fluid or some other contaminant in the porosity of the aluminum.
Blunt tungsten.
To much current/heat.
-Enjoy
fh : )_~
Old Jun 13, 2010 | 11:37 PM
  #55
oreocreaming
Blunt tungsten.
-Enjoy
fh : )_~
x2 about the tungsten, etiher it was blunt or pointed like you'd use for steel unstead of rounded. also he tried to feed too much rod into it.
Old Jun 14, 2010 | 12:06 AM
  #56
Festus Hagen
Methanoholic
Something else I just though of, he may be grinding his tungsten horizontal versus vertical...
What I mean by that is when you grind your tungsten you grind it so the grinding marks go lengthwise (or along the length) of the tungsten, not cross ways to the length.
That causes a large uncontrollable arc.
-Enjoy
fh : )_~
Old Jun 14, 2010 | 12:18 AM
  #57
RCrawler's Avatar
RCrawler
What about a slight interference fit between the caps and nipples and using Loctite sleeve retainer?
Jason
Old Jun 14, 2010 | 01:46 AM
  #58
Festus Hagen
Methanoholic
Been there already, he feels that would be inadequate do to the vibration.
I disagree, a good interference fit can be very strong, however there is a depth/diameter ratio that ultimately determines the strength, if the bore isn't deep enough for the diameter they can be weak. I don't know the formula, but I do know that it should be at least as deep as the diameter for maximum strength.
IMO I don't think it needs to be maximum strength, there is not that much vibration.
Lots of components like that are made with interference fits.
-Enjoy
fh : )_~
Old Jun 14, 2010 | 07:06 AM
  #59
mechelement
Pressing a hollow cylinder into the side of a cylinder w/o a flat surface to start your press can lead to issues. Machining a flat would be unsightly and I'd lose depth. If there was a small burr in the bore during the press, it would cause a leak.
I have reference material upstairs from my mechanical elements in machine design class which walks one through the design of interference fits. I also have the machinery's handbook which simplifies interference fits.
Old Jun 14, 2010 | 10:07 AM
  #60
Festus Hagen
Methanoholic
And so do I ... I also have done it a thousand times if once!
But it's your choice, it's your project, I could care less what you know or don't, I know what I know and I know what I don't.
[edit]
Sorry, I should not have said that, it's not true, I do care!
(Underlined cause STRIKE tags don't seem to work)
[/edit]
-Enjoy
fh : )_~
