EFI 5.0 swap
Old Jun 7, 2010 | 08:11 PM
aubreydavis0416's Avatar
aubreydavis0416
EFI 5.0 swap
Could anyone please point me in the right direction of doing a 5.0 efi swap in my 2003 edge, and no g_k i dont care to hear any smart remarks from you.
Old Jun 7, 2010 | 09:11 PM
g_k50's Avatar
g_k50
Too Little Too Late, check out Ranger Power Sport, that's what I posted along time ago when you weren't still listening.
Old Jun 8, 2010 | 08:09 AM
KhanTyranitar's Avatar
KhanTyranitar
Well, you should acquire the entire donor vehicle so you can pull whatever you need. You will need the PCM, and you will probably need to fab the motor mounts. But so long as you make sure you have all the parts off the donor vehicle, it is straightforward as far as swaps are concerned. I believe there are kits to help the swap along.
Old Jun 8, 2010 | 08:42 AM
redman84's Avatar
redman84
A donor vehicle would be ideal. I've done some swapping and the donor is worlds easier than junkyard runs because most likely a junkyard in a convenient location from you won't have everything and it is a mega PITA to have to drive a long way several times for stupid little things that you don't think of. Plus the donor vehicle may have many other things that you want off of it and then when you're done, sell your old stuff, part the donor out and voila, you make money back, break even, or even profit on a super duper f n bad@$$ swap. Just think of it as a parts store in your driveway with the exception of things like pilot bearing/bushing, throwout bearing, gaskets, etc that you don't want to reuse but hey, those are cheap!
Old Aug 1, 2010 | 12:11 AM
grandmas77f150's Avatar
grandmas77f150
Just find a late 90's Expo with a 5.0 and buy the whole thing. The motor will almost be a drop in
