Sponsored by: Real Truck
H.I.D's
Old Jun 9, 2010 | 08:36 PM
tolliewolly's Avatar
tolliewolly
so i take it that these units are pretty durable?
Old Jun 10, 2010 | 07:33 AM
grec-o-face's Avatar
grec-o-face
As long as you're not abusive to them, they are in fact very durable. Don't handle the bulbs with your fingers, don't mount the ballasts somewhere you know will get VERY hot or VERY wet. That's it.
I normally mount the ballasts with the connectors pointing down (in hopes they won't collect water as easily). Most of the time I use 3M double sided tape. Clean the surface of the ballast and the place you're mounting to, thoroughly (I use brake-cleaner) and you're good.
For the fogs on Super Duty's, I like to mount them right above the fog lamps, on the plastic bracket. Again, I clean everything and double tape them. But I also ran a few good sized zip-ties around them figuring they were more open to the elements than normal. You can't see 'em because they're up high -
If you have a front license plate - it's a bit tight to work up there - otherwise, it's not bad.
I've done cars, trucks, bikes, and plows, and had great results. Minimal issues.
Enjoy!
I don't have any experience with the 55 watt units... yet. I've always been happy with the 35's - but I plan on trying the 55's just to see (no pun intended) what the fuss is about.
Old Oct 14, 2010 | 07:05 AM
douglasl330's Avatar
douglasl330
Originally Posted by grec-o-face
I'm running 35 watt units, but mounted my fog ballasts exactly where you did. Even through the blizzards, been fine.
I also converted my Fisher plow gear to 35 watt HIDs. Mounted the ballasts right inside the light buckets.
Got any pictures of fisher upgrade? Thanks!
Old Oct 14, 2010 | 08:50 AM
grec-o-face
Old Oct 14, 2010 | 09:15 AM
douglasl330
nice job--I had thought about doing it--still have n't because I was worried bout heat and the ballasts, didn't want to lose any $$ do to an upgrade. -looks good--biggest issue about Fisher MM's is the lighting! Now I know it's been tried and works- I'll give it a go b4 the snow flies
Old Oct 14, 2010 | 09:33 AM
grec-o-face
Thanks.
It's currently got bi-xenon 6000k's in them, but I'm ditching the hi-low and going single beam (for ease of wiring) and I think I may drop to a 5000k or 4300k. The lower temperature will help avoid reflection from the snow.
Old Oct 14, 2010 | 09:59 AM
Ford Bandit's Avatar
Ford Bandit
Correct me if I'm wrong, when you install the HID lights, you lose the high beam/low beam, right. There is no switching back and forth?
Old Oct 14, 2010 | 10:40 AM
grec-o-face
Negative. You can still run hi/low, it just requires more wiring (direct power from the battery). I haven't used hi beams for a while, so I know "low only" won't be a problem for me. I can eliminate running an additional power feed that way.
Old Oct 14, 2010 | 11:41 AM
tolliewolly
it wont blow them up or anything if you get single beam instead of the dual?
I installed a set on a truck and I hated running that power cord. I can tell the single beam will work fine. I want to avoid running that battery wire.
AGrayson84
Dec 18, 2016 07:52 PM
05 f250 6 inch lift
Jun 29, 2016 07:40 PM
Darekr
Aftermarket Products
Apr 6, 2016 12:42 AM
03_superduty
Jul 21, 2011 02:48 PM
