Question! I am having problems connecting the Clutch line back into the Slave Cylinder. (This is a quick disconnect line) The connection does not appear to want to connect and grab. I do not want to force it since the line is plastic. There is a white sleeve over the male portion that is used to detach it from the female end. Reason I disconnected was to change out the throw-out bearing. I have done this once before and had no problems reconnecting this line. But this is not the case this time. Any help and welcomed and thanked very much.
