Leaking carb?
Old Feb 4, 2003 | 09:02 PM
Rat wagon's Avatar
Rat wagon
Leaking carb?
I got a 74 360 2v that hisses in the carb. I haven't replaced
gaskets yet but if that doesn't fix it, can the carb leak vacuum power?When warm it has a weak idle, but will rev to 5500rpm as fast as a ricer can. it won't idle after a cold start for 10 minutes or
so.
Old Feb 4, 2003 | 09:45 PM
Chas1234's Avatar
Chas1234
Leaking carb?
Lots of time with age the metal of the carb becomes porus and will cause leaks ... try rebuilding it see if that helps ...If water can erode rocks over time what do you think happens to a carb?
Jon
