Help with new tranny cooler install
Old 06-07-2010, 01:09 PM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
I bought a NAPA True-Cool tranny cooler because with these hot Texas days I want to prolong my Trannys lifespan. I am assuming I need to install the cooler in the return line to the tranny.
Can someone tell me which line is the return line to the tranny, I think it is the one that is on the drivers side of the radiator?
Should I disconnect the line from the radiator put in a fitting and run the hose to the cooler then tie back into the line to the tranny?
Can someone also tell me what size fitting I will need to connect to the bottom of the radiator (male) and what size to tie into the line back to the tranny (female)?? The cooler hose is 3/8" so I know one end will be 3/8" barbed it the other end i'm looking for.
I am sure I am making this alot harder than it really is.
Old 06-07-2010, 01:28 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
The line coming from the oil-to-air cooler is the return line. It flows from the trans to the radiator, to the cooler, then back to the trans... I would get a 3/8ths double-barb, cut the line from the cooler, route it to the new cooler, then run another line from your aux cooler back to the steel line going to the trans. Should only take one double-barb fitting & a couple hose clamps, if I'm thinking of this correctly...
Old 06-07-2010, 02:33 PM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is offline
That is exactly right Joe
Old 06-07-2010, 02:50 PM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
Am I going to have to remove the intercooler or the radiator to get to the line i am going to need to cut into? I am going to mount the cooler in front of the ac condensor coils. I dont know how much room is between the intercooler and the radiator if I want to put to put this new cooler there but I doubt it. I guess I should have taken a peek before I dove off into this head first!!
Old 06-07-2010, 04:06 PM
HKusp's Avatar
HKusp
HKusp is offline
Nope, it almost takes longer to take the tools out and get everything ready than it does to put that thing on. You will like your numbers when it's done.
Old 06-07-2010, 04:12 PM
HKusp's Avatar
HKusp
HKusp is offline
Just put it in front of your radiator. You want it to get nice cool air.
Old 06-07-2010, 10:44 PM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
Jason the cooler I put in is the same one you have. I should have mounted it off center because after I put my grill back on I saw how the big ford emblem in the grille blocks off the center of the cooler If it does not cool as well as I expect I should be able to get some new hold down straps and move it to the left.
All in all it was a pretty simple install but I did have to remove my front bumper to get to the clamp on the factory cooler. That was the only PITA part of the whole job. Even with having to remove the bumper it only took 3hrs start to finish an was only a 4 beer job (hey it was really really hot outside!)
Thanks for posting the pics it really helped! Reps to you and Joe!!
Old 06-08-2010, 07:40 AM
HKusp's Avatar
HKusp
HKusp is offline
Man, that sucks that you had to remove your bumper. Mine took less than 30 minutes and that was going slow. I doubt your Ford emblem will cause it too much trouble. Air should flow around it very well. Let us know what your numbers are.
Old 06-08-2010, 09:20 AM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
I am going on a 4 hr road trip this weekend towing my boat so i should be able to see the real benefits of the install. I will post back Monday with the temps.
On my morning commute to work I saw a 30deg drop in tranny temps but it only take me 20-25mins to get to work and I never get over 40mph.
mribbich
07-23-2016 09:02 PM
SuperDutyScaler
1999 to 2016 Super Duty
17
07-20-2016 03:24 PM
Island'r
12-28-2015 10:45 AM
JefflovesF250s
39
01-16-2015 01:14 AM
truzoom
1997 - 2003 F150
06-06-2010 08:09 AM
Quick Reply: Help with new tranny cooler install
