PCM-ICP sensor question
Old Jun 9, 2010 | 05:49 PM
Action4478's Avatar
Action4478
If you are going to test the voltage on the IPR ,I did it at the wires on the connector ...
Old Jun 17, 2010 | 06:18 PM
drivembig's Avatar
drivembig
First of all I would like to thank everyone that has helped on this problem and all others that I have posted about.
I received my new ICP sensor today and installed it. My problem was cured without changing the PCM.
I now have the PCM that is in my truck and one from a 97 model with a flash of TDE1. I was told that the newer one would read codes from a standard code reader that my older one would not.
Should I use the old one that is working fine now, or install the 97?
Again, any help would be greatly appreciated. Thanks.
Old Jun 17, 2010 | 06:33 PM
Action4478's Avatar
Action4478
I would use the TDE1 , see what you think. It is the latest of them all ...(best)
forensicpsyguy
Nov 24, 2019 02:59 PM
navistarnut
Oct 19, 2018 01:53 PM
jtharvey
19
Apr 15, 2012 03:44 PM
forensicpsyguy
Feb 14, 2010 03:38 PM
phydiux
Nov 4, 2008 09:49 AM
