6.0 2004
Old Jun 7, 2010 | 12:05 AM
350crew4x4's Avatar
350crew4x4
I am new to the site and new to diesels, Before this truck I had a 2000 350 crew/V10 , I brought home a 2004 6.0 power stroke turbo and it has an oil leak. It looks like its coming from some where on the upper back right side of the motor. Looks like its trailing down from above the starter housing. When I bought the truck it came with a repair invoice that said these things were just completed; oil filter, fuel filter, air filter, engine oil 15/40, grease, injection control module installed and programmed, 04-07 6.0 L injector, shop labor , tax . I know the person that I bought it from and it has never leaked before? The mileage on there invoice and what the truck reads now is 212536/212737 the repair shop is 124 away from where I bought the truck. Is this something that could have just started or may have something happened at the shop in their repair that could have caused this to start leaking ?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Anything at all would be helpful.<o></o>
Thanks in advance<o></o>
<o></o>
Old Jun 7, 2010 | 05:30 AM
bismic's Avatar
bismic
Welcome to FTE 350crew4x4.
The first thing is how bad is the oil leak - can you quantify it?
Next, do you have an early or later model 2004? This is easiest determined by locating the ICP valve.
Early model year ICP:
https://www.ford-trucks.com/forums/a...pictureid=8586
The early model years have them under the turbo. When they leak, they can leak quite a bit down the fire wall on the passenger side.
The later model years have them on the passenger side valve cover, by the passenger side glow plug module.
https://www.ford-trucks.com/forums/a...ictureid=14353
Leaking ICP sensor:
https://www.ford-trucks.com/forums/a...ictureid=12281
There are actually many places that can leak. Most trucks will have a hanging drop of oil, but no spots on the driveway. The Tech Folder has a list of oil leak locations.
https://www.ford-trucks.com/forums/a...p?albumid=3099
Tech Folder
https://www.ford-trucks.com/forums/3...ch-folder.html
Oil Leak thread:
https://www.ford-trucks.com/forums/8...att66f100.html
dk4182
May 19, 2016 10:30 PM
Joe in Austin
Nov 18, 2012 10:58 AM
TexasEX2K
Jul 5, 2012 10:46 PM
cajun250
Jan 5, 2012 09:00 AM
Texas 6.0
May 24, 2011 11:22 AM
