Selecting a secondary spring
Old Jun 6, 2010 | 09:35 PM
sum_weirdo's Avatar
sum_weirdo
I put a Holley 4160 on my 78 F250 a few years back and from the start I couldn't get full opening on the primaries because of the pesky throttle rod that Ford decided to use. Today I tried to fix that by making a bracket to reposition the throttle lever stud and it was a mild improvement but I'm finding the geometry just doesn't work unless I move the carb higher off the manifold, which I can't do without changing my air cleaner.
Forget that, now I'd like to improve performance by changing the secondary spring, I believe there's a black one in there now, the stiffest of the whole set. Here are the facts:
-Basically stock 78 460 with a glasspack.
-750 CFM Holley 4160 with maybe 2/3 opening on the primaries
What spring do you think I should try for a little more passing power?
crazyeddie
Aug 5, 2010 09:35 PM
HawgDawg
Mar 31, 2008 10:56 PM
76supercab2
15
Jul 18, 2006 02:55 PM
airharley
Jan 30, 2002 08:27 PM
