Towing Capacity
Old Jun 6, 2010 | 05:00 PM
leardvr's Avatar
leardvr
Towing Capacity
I just need the numbers for the '92 E350 138" WB, 7.5L, 4.10 gears.
I have the OEM towing package, trani cooler, HD springs, W/D and sway control hitch, understand frontal area, GVW, and GVCW ect....
I just need the number. I'm guessing about 9000lbs
Old Jun 6, 2010 | 05:46 PM
rebocardo's Avatar
rebocardo
1990
Your setup
3.54=9000
4.10 was 10,000
Old Jun 6, 2010 | 06:16 PM
gearloose1's Avatar
gearloose1
Now for safe handling, easy maneuvering, and white knuckle free towing, derate it by 20 to 30%.
Old Jun 6, 2010 | 06:22 PM
leardvr's Avatar
leardvr
Originally Posted by rebocardo
1990
Your setup
3.54=9000
4.10 was 10,000
Perfect thank you, can't believe 3.54 only cost me 1000lbs. Might be worth a switch.
Originally Posted by gearloose1
Derate that
Yupper always do. Won't tow unless I have a 25% reserve. So in this case nothing more then 7500. My trailer typically loaded is 7450.
Old Jun 6, 2010 | 08:25 PM
gearloose1's Avatar
gearloose1
With that level of derating, you have a whopping safety margin even if your brakes are nearly worn, if the trailer is not quite well balanced, and the tongue weight not quite right, or what not.
I learned my lesson the hard way when once, I towed a 7,500lb trailer with a vehicle "rated" by a maker (not Ford) for 7,000.
It was hairy -- and I kept monitoring the tires (which were squatting pretty low) and heating up during the tow.
From that time onwards, I slashed what the makers claimed by a lot... and enjoyed every one of my tows.
Especially when I pass by an overturned truck-trailer that clearly, was either at the towing limit or over.
Godspeed.
Old Jun 8, 2010 | 03:46 AM
rebocardo's Avatar
rebocardo
I doubt it, it is going to be about 10 mpg no matter what you have with the 460. The only ones I have seen get good mpg where EFI trucks with the 5 speed.
beeser
Jan 3, 2014 01:17 PM
80broncoman
Feb 26, 2013 12:30 PM
Canty
Mar 15, 2011 08:49 PM
Kijutsu
1997 - 2003 F150
Jul 8, 2006 12:40 PM
ksubuck
Nov 13, 2005 09:30 PM
