Door latch keeps popping open
Old Jun 6, 2010 | 03:46 PM
460MAGNUM's Avatar
460MAGNUM
The second door top latch pops open for no reason. It sometimes happens after 15 minutes of driving or as much as an hour or two . . After 3 trips to the dealer last year they replaced the cable in the door and it worked well for about a year , Now the problem is reappearing . Anyone else with this problem on their van ? Mine is a 2008 E-350 , if there is any help you could offer or suggestion on how to fix it instead of taking it back to the dealer .
Old Jun 6, 2010 | 04:09 PM
Grems4ever's Avatar
Grems4ever
Personally, I'd wonder about the alignment of the door. It sounds like a wear problem which would explain why the new latch lasted only a year. Might be worth letting a body guy look at it and give you their opinion.
Old Jun 6, 2010 | 06:17 PM
gearloose1's Avatar
gearloose1
Alignment of door, and is the frame broken?
Old Jun 6, 2010 | 10:45 PM
460MAGNUM's Avatar
460MAGNUM
I will have them check on door alignment . Its still under warranty so I will keep bringing it back till its fixed right .
oldfordtrucksrule
1997 - 2003 F150
Mar 10, 2015 08:02 AM
fordguy55
Jul 9, 2010 09:54 AM
Franzh
Oct 23, 2008 08:37 PM
B/B ford
Jul 16, 2006 03:10 PM
94aerostar
Aerostar
Jan 11, 2004 09:02 PM
