Transmission ID ?
Old Jun 6, 2010 | 12:09 PM
money pit 69's Avatar
money pit 69
Question Transmission ID ?
Good morning I recently aquired a 1972 Olson Kurbmaster stepvan. It is cool its propane fueled. It seems to have ford running gear. Its powered by a 300 6. My registration here in Wa. calls it out as a ford van. Am I to think that all of the running gear is ford. My problem is yesterday I started changing the filter and fluid in the transmission. All went well until I went to the parts house to get a new filter and gasket. None of the gaskets for the ford trans. matched mine. The filter was the same but not the gaskets. My pan has (14) pan bolts as does the FMX/Cruiseomatic according to LMC'S catalog but the new gasket way different.. The C-4 only has (11) bolts and the C-6 has (17). How can I find out what trans. this thing has in it. HELP THX David
Old Jun 8, 2010 | 12:04 PM
jk080's Avatar
jk080
Transmission Rebuilder
If you could take a picture of the transmission that would help, or just the pan.
Old Jun 8, 2010 | 02:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Do the front doors slide back/forth? If so this is a P Series Parcel Delivery, once used by UPS, Frito-Lay and countless bakery's.
It was once commonly known as a bread (delivery) truck.
Ford sold the P Series rolling chassis to body makers, who installed their own bodies. These chassis were also used for Motor Homes.
No FMX's were installed in any of these trucks. It can't be an Econoline chassis, because Econolines of this vintage only came with C4's (1965 thru 1974).
What you have is MX Cruise-O-Matic, once called the BIG Cruise-O. It has 14 trans pan bolt holes.
This same A/T was used in 1965/67 F100/350's w/352's / 1965/72 F350's with the H/D 300 I-6 / 1961/67 390 Passenger Cars.
The pan gasket is specific to the MX trans, it is not the same as an FMX or the FX C-O-M used in 1958/67 Passenger Cars with 352's.
But...this same MX gasket was also used in 1955/57 Thunderbird's with Ford-O-Matic.
B5SZ7A191B .. Transmission Pan Gasket / Obsolete / If you cannot locate this pan gasket at an autoparts store:
DON SANDERSON FORD in Glendale AZ has 12 = 623-842-8762.
MILLER OBSOLETE PARTS in Binghamton NY has 38 = 800-543-4959.
GREEN SALES CO. in Cincinati OH has 45 = 800-543-4959.
Sanderson will prolly be cheaper and is the closest source to WA that has any.
fordcrzymike
1997 - 2003 F150
Jun 27, 2017 10:00 AM
Acab1
Oct 22, 2016 03:05 PM
DAT2109
Jul 11, 2015 09:36 PM
Corpsman24
Aug 19, 2013 10:18 AM
gthbryce
15
Apr 20, 2009 11:53 PM
