help with hubs
Old Jun 5, 2010 | 05:11 PM
tat2hoot's Avatar
tat2hoot
Unhappy help with hubs
have a 72 f100, currently has 8 lug 16in wheels. is there any reason why it would not be as simple as changing hub/ rotor assembly to put wheels on that i want? or, what do i have to do to put a nice set of cregar (for example) mags on it?
Old Jun 5, 2010 | 07:35 PM
sandmanf250's Avatar
sandmanf250
wheels
if you have an f-100 you dould have 5-5 5lug wheels whatdo you have son.
Old Jun 7, 2010 | 03:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No F100 came with 8 lug wheels, which have a 6.50" bolt circle pattern. These wheels were used on 1953/96 F250's and 1967/96 F350's.
All 1953/79 F100's came with 5 lug wheels on a 5.50" bolt circle as did all 1975/96 F150's.
Some 1980/83 F100 wheels have a 5.50" bolt circle, some have a 4.50" bolt circle.
If your trucks VIN begins with F25 (F250) or F35 (F350), it's not an F100, which begins with F10.
Old Jun 7, 2010 | 10:36 AM
myutesux's Avatar
myutesux
POST SOME PICS
Old Jun 8, 2010 | 01:13 PM
tat2hoot's Avatar
tat2hoot
ok, now i am confused. it is a 3/4 ton pick-up, but it says clearly on the truck 100. vin no. f10ylm63757
Old Jun 8, 2010 | 01:51 PM
NumberDummy
F10 = F100 2WD
Y = 360 2V.
L = Michigan Truck Assembly Plant
M63757 = 1972.
Where did you find this VIN? On the registration, or from the Warranty Plate, which is located on the left door face below the latch?
People replaced damaged left doors with used doors. 99% of the time they did NOT install the original Warranty Plate on the replaced door.
If it has 8 lug, 6.50" bolt patterned wheels, it could also be an F350, as the same wheels were used for both.
tat2hoot's Avatar
tat2hoot
really confused now
it is a 3/4 ton pick-up but, it says 100 on the truck and the vin no. does start with f10
Old Jun 8, 2010 | 01:59 PM
tat2hoot's Avatar
tat2hoot
on the title. issued 5/25/77
Old Jun 8, 2010 | 02:56 PM
tat2hoot's Avatar
tat2hoot
i really believe that the truck is all original. i am only the 3rd owner.
Old Jun 8, 2010 | 03:10 PM
NumberDummy
It cannot be all original if it's an F100 with 8 lug wheels.
How many 1953/83 F100's came with 8 lug wheels? N-O-N-E = NONE!
Not only are the wheels between an F100 and F250 different, but so are the front/rear brakes, front/rear suspension, rear axle and the frame...just to name a few things.
My guess is...someone lost the title, or bought the truck as a theft recovery or from a junkyard, then used a title from an F100 to register it.
Or, a former owner swapped frames using one from a F250 on an F100.
Old Jun 8, 2010 | 04:34 PM
tat2hoot's Avatar
tat2hoot
number on title matches number on door. all that aside, what can i do to put wheels i want on the truck?
Old Jun 8, 2010 | 05:40 PM
sandmanf250
what you can do
go to a wheel store and see what fits then pick your style @ride happy.
Old Jun 8, 2010 | 06:29 PM
tat2hoot's Avatar
tat2hoot
wow, really? that's it? there's no way i can change that? i guess i had hopes of a certain look i was after, but, i guess i'll just have to think along a different line, huh? thanx for the advise. it's crazy, it seems i don't even know what i have. i've posted some pics. would u please take a look and tell me what you think?
Old Jun 8, 2010 | 11:02 PM
tat2hoot's Avatar
tat2hoot
got some pics in profile album. can you look at and tell me what you think, please?
Old Jun 9, 2010 | 02:19 AM
RichS2659's Avatar
RichS2659
Check the vin on the driver's side cab sticker and also on the frame . Someone could have changed the cab at one time or the door. Does it have a reconstruct title? Unless somebody changed out the front spindles and hubs and the rear axle to a Dana 60.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
