Im having trouble trying to id the trans in my 86, I found a number on the side (13-09-065-911) Do I have the T18 or the T19? Also, whichever Transmission I have is it going to make a difference with my ZF swap?
T-19 has a PTO cover plate on both sides, T-18 only on passenger side.
And why would it matter?
Be sure and get a flywheel that fits the new clutch you need for the input splines on the ZF.
If the trans is the original, it's a Warner T-19 4 speed, as this was the only 4 speed available with the 460 engine at this time.
The TRANS code is marked on the Certification Label: P = Warner T-19.
