7 pin trailer plug-- HELP
Old Jun 5, 2010 | 04:17 PM
packleader's Avatar
packleader
Cool 7 pin trailer plug-- HELP
Hi,
I'm new here and just recently got a 2001 Excursion 7.3 Diesel. I've pulled my trailer with it twice and have been having truouble with the lights and thought replacing the connector truck side might help. Soooo, I took the 4 screws out and can't for the life of me figure out how to get the plug out. It looks like it should pull apart if you press a piece of plastic that looks like it locks it but it doesn't. I also doesn't look like the wires are on pins that pull out. It is the original plug. Any suggestions or help would be appreciated as I need to be able to pull my trailer later in the week.
Thank you.
Old Jun 5, 2010 | 05:00 PM
myblkex's Avatar
myblkex
Originally Posted by packleader
Hi,
Thank you.
Not sure what your original problem with the lights was -- but I had a problem with the parking lights not working on my trailer when I first got the Ex and it was a relay under the hood. Changed it out with the power windshield washer relay next to it and all the lights worked fine --
Hope that helps a little...
Old Jun 5, 2010 | 05:33 PM
packleader's Avatar
packleader
It started with the break controller and then was the right turn signal then the running lights. The pins in the plug are visably worn which is why I thought I should replace the plug. Thank you for the suggestion though..
Old Jun 5, 2010 | 06:47 PM
DaveandJennyP's Avatar
DaveandJennyP
I believe the only place to get that whole assembly is from FORD and it's like $150. I asked on here if i could replace just the flat 4 part and was told it was all one piece and to just get a 7 to 4 adapter instead. Let us know what you figure out.
Old Jun 5, 2010 | 06:52 PM
packleader's Avatar
packleader
this one doesn't have the flat four part just the round part that you can plug the trailer into or the round adapter to go to four prong. I can cut the wires but it seems like it should come aprat a either be able to unscrew each wire or pull each wire loose. I swear it's like a chinese puzzle!
Old Jun 5, 2010 | 07:07 PM
djdrexler's Avatar
djdrexler
before you mess with anything,make sure your grounds are good. then use wd40 on all connectors and sockets. This almost always works.
Old Jun 5, 2010 | 07:12 PM
DPorter's Avatar
DPorter
yes it will separate at the plug. However on the drivers frame rail behind the spare is the harness plug to unplug the 7 way. This is were I had a corrosion issue with mine. I hard wired an aftermarket 7/4 way for $50.
Bob Landry
Oct 27, 2013 07:20 PM
CobraGT40
Aug 26, 2013 09:17 AM
FloridaStroker
All Things Towing
19
Jun 15, 2013 07:22 AM
mitsudave
1997 - 2003 F150
13
Oct 24, 2012 06:27 PM
blighty
Electrical Systems/Wiring
Jan 5, 2008 08:10 PM
