I am working on 92 F150 custom, inline 6, 4 wheel drive. No power is going from the fuel relay switch to the fuel pump. It has a single tank in the back. I have check all the fuses and relay, fuel pump, the and everything from what I looked up checked out clear. So the only problem is from my relay to the fuel pump to give it power.
Hi Glenn Cofsky! It looks like you've randomly posted a tech question on the tail end of someone else's "New Member Introductions" thread. You might want to start a separate thread to introduce yourself. Also, since the folks that have answers to your kind of questions don't usually frequent the "New Member Introductions" forum, you might want to post your issue in a new thread in the "1987 - 1996 F150 & Larger F-Series Trucks" forum.
So my 89 f150 turns over but start... It'll start for a second when I spray starter fluid then die... My guess it's not getting gas but don't know where to start.
I'd say next step is to see what the fuel delivery problem is. The folks that know about this sort of thing don't often visit the "New Member Introductions" forum. You might want to start a new thread over in the "1987 - 1996 F150 & Larger F-Series Trucks" forum for more answers.
