fuel system mods
Old Jun 5, 2010 | 01:37 PM
Mat J's Avatar
Mat J
fuel system mods
I want to redo my whole fuel system, and get rid of the stock pump and get rid of the entire fuel bowl.
I am thinking about putting in an air dog or air dog2 what is the difference? Also will be doing the intank mods and getting new fuel lines.
What do I need to do to get rid of the stock regulator and connect the fuel rails in the heads and add a under hood gauge?
Old Jun 5, 2010 | 02:10 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
if money is no object then order the regulated return and fuel bowl delete from dieselsite and i think you mught be able to get the air dog from him as well but youll love the reg return system and he has great customer service.........
Old Jun 5, 2010 | 02:20 PM
Mat J's Avatar
Mat J
money is an object but its its worth getting i will get it. i need something that will support bigger injectors. i am planning on 450-500hp with this motor. i checked diesel site and they are out of stock on both there kits for the 7.3
my neighbor is a dealer for air dog so i can get that set up just want to make sure its a great as he says, also does riff raff sell a regulated return or just the crossover hoses?
Old Jun 6, 2010 | 12:39 AM
ajorn's Avatar
ajorn
fuel
I redid my whole fuel system. The only reason that I did it was the existing fuel system was hacked up and I didn't like it. I have a FASS and a DIY RR. All new fuel lines and intank mods. If nothing is wrong with your current setup I would do the intank mods, replace the fittings and keep the stock setup. You can get fp shims from RR, add a fuel pressure gauge and keep an eye on things...you'll end up spending a good amount of money if you redo your whole system when it may not be necessary...
Old Jun 6, 2010 | 01:02 AM
Mat J's Avatar
Mat J
ok thanks, i want at least 450hp when im done with this thing so i dont want to redo the fuel system twice.
Old Jun 6, 2010 | 02:00 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Do the in tank mod. That will eliminate the air in fuel problem. Put a pre pump filter in. Regulated return. Fuel bowl delete if you wish. For piece of mind go with a after market pump. (keep the stock as spare) Walbro and Bosch are popular. Wack on a fuel pressure gauge and you are good for 500.
Old Jun 6, 2010 | 05:21 AM
ron's power stroke's Avatar
ron's power stroke
call and ask for Sam's weekly rate on this RR kit...for a rubber hose set up I like this kit..the hose will not chafe, rot, kink or burn...you can tie these hoses in a knot and wire tie it right to the exhaust housing on the turbo and will not hurt the hose at all..
Diesel Innovations regulated fuel return kit
to do a complete fuel mod will run you 800 to 1200 bucks..there is no cheap way out...
I have the fuel lab pump with a sump on the tank..to use it I need to run 5/8 fuel line from the tank to the 2 micron filter..then run 1/2 line to the RR..for the return fuel I will be running 3/8 back to the tank...read the spec's on the air dog for fuel lines..if it isn't what they want...your warrantee is worthless..
Tom Callan
Feb 15, 2014 02:22 PM
01EX
Jan 24, 2011 07:08 PM
jg96powerstroker
42
Jan 1, 2011 06:05 PM
brickie
Apr 10, 2009 10:24 AM
crowes99
Jul 28, 2007 08:29 AM
