6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
how important is 10k fuel filter replacement?
Old Jun 4, 2010 | 01:03 PM
weyland426's Avatar
weyland426
on another forum i mentioned that i still had factory fuel filters with 60k...someone was nice enough to inform me not to let ford know this for fear of voiding warranty. i had my local shop change them out a couple days ago. at almost $200 for the kit and installation(would have to be near $300 at a dealer), i have to ask...is this REALLY necessary every 10k like the maintanence schedule says? damn!
Old Jun 4, 2010 | 01:12 PM
senix's Avatar
senix
one word..extremely!!
You can do it yourself for alot less. Have Ed from www.partsguyed.com send you some.
These fuel systems are very touchy. I am really impressed that you have not had any issues.
do you drain the fuel/water separator monthly?
Old Jun 4, 2010 | 01:55 PM
69cj's Avatar
69cj
I'm not positive but I think the 6.0 and 6.4 use the same filter kits and I pay between 40 and 50 bucks for them and 1/2 hour to change taking my sweet time about it. And I do use OEM Racor filters. <!-- / message --><!-- sig -->
Old Jun 4, 2010 | 02:36 PM
pyro2nite's Avatar
pyro2nite
Check the cost of your injectors. That will answer your question
Old Jun 4, 2010 | 02:45 PM
RoadJunkie's Avatar
RoadJunkie
Don't confuse price with cost...change the filters.
Old Jun 4, 2010 | 02:58 PM
R-T0r21on's Avatar
R-T0r21on
My maint schedule says 20,000 miles (normal use). That's what I've been going with. You can go with the heavy use schedule if you wanna. Or, split the dif. and go 15,000.....It is very important though to DO IT! 60K is crazy. You're lucky so far, but I wouldn't push your luck anymore.
Old Jun 4, 2010 | 04:22 PM
F0rdFre@K's Avatar
F0rdFre@K
I do mine at Valvoline for $115.00. Buddy of mine works at the local Stealership and now gets me parts at employee cost. So, I'll be able to do them for $60.00 now.
Old Jun 6, 2010 | 03:29 PM
UGA33's Avatar
UGA33
As sensitive as the fuel system is on the 6.4L to contaminates and water, the filters need to be as fresh as possible. The filter kits for the 6.0L and the 6.4L are different. The primary filters are the same size, but the secondary filter on the 6.4L is quite a bit larger than the 6.0's.
Old Jun 6, 2010 | 06:57 PM
jac08f250's Avatar
jac08f250
300 bucks at the dealership for fuel filters and to replace them? The one I go to only charge 130 to replace them. But I'm still going to do them myself.
Old Jun 6, 2010 | 07:02 PM
69cj's Avatar
69cj
I do mine every other oil change which would be 10,000 miles. At 50 bucks a kit you can change a lot of filters for the price of an injector plus your down time. They are simple to change, learn to do it.
Old Jun 6, 2010 | 07:12 PM
jac08f250's Avatar
jac08f250
What type of oil do you use to change it every 10k miles? I was told to do it every 5k.
Old Jun 6, 2010 | 07:18 PM
sdetweil's Avatar
sdetweil
he changes his fuel filter every OTHER oil change.. and changes oil at 5,000miles
so the fuel filter would be every 10,000 miles
Sam
Old Jun 6, 2010 | 07:20 PM
jac08f250's Avatar
jac08f250
Sam
My eyes are quickier then my mind.
Old Jun 6, 2010 | 10:13 PM
gearloose1's Avatar
gearloose1
In engineering, that is called an "opps"......
I am pushing to see if we can get the secondary filter separately.
It needs a lot more frequent changing than the big one.
Old Jun 6, 2010 | 10:37 PM
sdetweil's Avatar
sdetweil
I keep a watch on Ebay for the ford/Motorcraft filters, and buy when I find them. that way I am stocked.. I usually find a set for $35-40..
Sam
