piston specs needed
Old Jun 4, 2010 | 02:08 AM
Rust is too a color's Avatar
Rust is too a color
piston specs needed
Im knee deep into an inframe that I should NOT be doing alone. Started out just changing gaskets. Sigh. Looking for bore, piston, clearance, and ring specs for a '66 300ci 6cyl. Im hoping to save the pistons assuming tolerances are still good, but every compression ring is in pieces. If Im missing anything else, its ignorance not failed memory.
