M5OD
Old Jun 3, 2010 | 08:54 PM
bazzman1953's Avatar
bazzman1953
M5OD
Will a tranny out of an exploder fit my truck, and if so what year(s)?
The B-4000, not the F-150. I really miss the little truck and the big one now has a busted frame so it is quite limited on its usefulness.
Old Jun 4, 2010 | 02:27 AM
keydr's Avatar
keydr
Shouldn't be a problem fitting. Everything I can find pretty much says 94-2001 for the
M5R1. But they should be the same even back to 1991 in the Xploders.
Old Jun 4, 2010 | 03:02 AM
R031Kona's Avatar
R031Kona
For sure, the Ranger Station tech section says all the V6 transmissions interchange....
Old Jun 4, 2010 | 01:01 PM
keydr's Avatar
keydr
That's what I was thinking too, I was pretty sure the bolt patterns were the same.
Old Jun 4, 2010 | 06:41 PM
crerar's Avatar
crerar
I'd qualify that a little. You (Bazzman) have a 4.0 liter - stick to 4 L transmissions and you should be good (and of course replace a 2wd with a 2wd, 4wd with 4wd )
The 3 L (OK probably not a lot of those in explorers!) has a different bolt pattern and the M5OD has an integral bellhousing. The 2.9/2.8 and 4.0 share their bolt patterns, but the 2.9 trannies were reportedly lighter than the 4Ls ...)
Old Jun 4, 2010 | 10:50 PM
R031Kona's Avatar
R031Kona
Thanks for doing the qualifier for me, if you take a look at the time stamp....... explains all
Old Jun 5, 2010 | 11:05 PM
bazzman1953
Thanks for the feedback! I was aware that the 3.0 and 4.0 had different bolt patterns, but others might find that a heads up. I miss my bloody truck! The F-150 served its purpose, ie. it got me through last winter w/4wd. And for $150 bucks it did quite well. Too big a truck for me. I like the 8 ft. bed on it as I can haul my 15' jonboat in it, outside of that my little truck can do anything it can do, including carrying my quad, with a 5+mpg boost.
dieselsubmariner
Nov 3, 2014 01:18 PM
Vinford
16
Feb 15, 2014 08:04 AM
48fordcoe
Mar 9, 2008 09:46 PM
Hiflyer746
Mar 8, 2007 12:38 AM
