Fan Clutch
Old Jun 3, 2010 | 05:34 PM
1999SuperD's Avatar
1999SuperD
Fan Clutch
Im needing to replace the fan clutch on my truck but it seems to be harder then i thought it was going to be so does anyone have any advice on how to remove it? Thanks
Old Jun 3, 2010 | 06:12 PM
Sheldon Plankton's Avatar
Sheldon Plankton
What exactly is the problem? Is the engine turning over when you try to loosen the bolt on the clutch shaft?
You can either:
a) Rent a fan clutch removal tool from NAPA, etc. This allows you to grab the pump pulley while you loosen the clutch shaft with a 1 1/8" wrench or a pipe wrench. Standard counterclockwise to loosen.
b) Hit a corner on the clutch shaft bolt with an air chisel and back it off.
c) Get creative with a C-clamp.
Hope this helps.
Old Jun 3, 2010 | 07:03 PM
1999SuperD's Avatar
1999SuperD
the fan clutch is locked up so it never disengages. I will look into getting the tool to remove it. Thanks for the info
Old Jun 3, 2010 | 07:55 PM
1999SuperD's Avatar
1999SuperD
Does anyone know where i can find a good deal on a fan because im not to excited about pay almost $200 for a fan clutch
Old Jun 3, 2010 | 09:04 PM
clintbonnie's Avatar
clintbonnie
Here is good info on Fan Clutch problems....(especially post #10)
https://www.ford-trucks.com/forums/9...-too-much.html
Old Jun 9, 2010 | 10:46 PM
1999SuperD's Avatar
1999SuperD
Weirdest thing its back to normal now. I guess it unfroze but now it works just fine stays cool and everything
FastMatt
Jun 20, 2014 10:05 PM
steve340
May 10, 2014 07:20 PM
johnsjsj
17
Aug 2, 2012 10:26 PM
cutlass
Jul 15, 2012 11:16 AM
j23
Jul 4, 2005 10:00 AM
