Pertronix upgrade
Old Feb 4, 2003 | 12:47 PM
prginocx's Avatar
prginocx
Pertronix upgrade
Recently installed the Pertronix upgrade with the 40k volt coil. Now I have excessive RF noise when I try to use a battery powered AM radio in the CAB. What can be done about this ?
Old Feb 4, 2003 | 05:54 PM
lrac's Avatar
lrac
Pertronix upgrade
What kind of wires are you using? Are they graphite resistance wires or metal? If metal you may want to change to graphite. Originally Ford had a loop in the wire coming from the coil tower to the dist. cap, sort of a half knot, which helped on the regular ignition with metal wire. You might try this. You may need a capacitor/condenser on the coil.
