Randomly bucking
Old Jun 2, 2010 | 08:45 PM
99f250craig's Avatar
99f250craig
Randomly bucking
Hi all, I have 96 f250 with 265,000 miles. I've noticed lately that at hwy speeds (55mph+) it will randomly surge or kinda buck for a second or two and then be fine. It only does it once a day. One night the CEL light came on and it dropped my speed from 70 to 60 then to 55. I couldnt accelerate anymore. I got home and took it back out and it was fine. Tried to pull codes but nothing came up. It almost seems like there is air in the line but it only does it at upper speeds. Any ideas? Thanks
Thomas
Old Jun 2, 2010 | 08:57 PM
oldbird1965's Avatar
oldbird1965
Could be the CPS but if your pulling hard it could also be your HPOP isn't putting out enough to keep up with the demand of your injectors.
Old Jun 2, 2010 | 09:05 PM
1997F-350's Avatar
1997F-350
LOW ICP CODE more than likely...what is an adrenaline hpop???? 17* pump or something? if so you should have more than enough oil...sticking ipr???
Old Jun 3, 2010 | 05:03 PM
99f250craig
Unplugged icp sensor, Idle changed for a breif sec then ran fine. Is icp bad?
Old Jun 3, 2010 | 09:30 PM
99f250craig
[quote=oldbird1965;8958515]Could be the CPS but if your pulling hard it could also be your HPOP isn't putting out enough to keep up with the demand of your injectors.[/quote
CPS, camshaft or crank position sensor?
Old Jun 3, 2010 | 09:32 PM
1997F-350's Avatar
1997F-350
could be i also saw an extensive tsb on this somewhere today...internet..type bucking psd...it even said bucking on the title of it from ford.
Old Jun 3, 2010 | 10:37 PM
oldbird1965
camshalf position sensor.
beemr
Feb 5, 2010 11:19 AM
machinemaker56
New Member Introductions
Apr 11, 2006 05:35 PM
Thomas A
Oct 30, 2005 02:35 AM
thomasgk
May 31, 2004 01:22 AM
Thomas Endicott
Sep 22, 1999 12:22 AM
