Newbie here, needs help and advice.
Old Jun 3, 2010 | 09:17 AM
farmert's Avatar
farmert
The picture that mabc926 posted is a 99 or later powerstroke. You can see part of the spyder for the intercooler, and it has the small cover you need for the intercooler tubes to fit. The 94.5 threw 97 strokes did not have an intercooler, and most had a larger plastic cover on them.
Old Jun 3, 2010 | 03:18 PM
94 smokin stroker's Avatar
94 smokin stroker
Exclamation
ok ill tell you more the air filter cover aint plastic it is cast iron and it has 4 bolts holding it on oil cap is on front middle of engine right behind radiator only words on intake are ford turbo looks just like the first pic joe f350 posted i am almost 99.9% sure it is idi
Old Jun 3, 2010 | 03:24 PM
94 smokin stroker
yes it is the top photo excatly the same engine
Old Jun 3, 2010 | 03:41 PM
joe f350's Avatar
joe f350
them u have a idi
Old Jun 3, 2010 | 03:44 PM
94 smokin stroker
ya it is deffinatley a idi if that picture is a idi then mine is
Old Jun 3, 2010 | 03:56 PM
94 smokin stroker
couple questions for you guys i got are my front tires throw out out at the bottom and in at the top when i back up but then when i go forwards even a little bit they get back straight as a string is this normal for the obs or idi trucks it has a d50 axle
Old Jun 3, 2010 | 04:04 PM
joe f350's Avatar
joe f350
is ur truck a f250 or 350
Old Jun 3, 2010 | 04:07 PM
zx250's Avatar
zx250
Of the next Riffraff East
Originally Posted by joe f350
them u have a idi
Thanks Joe, and this photo of yours is the IDI?
Old Jun 3, 2010 | 04:13 PM
joe f350's Avatar
joe f350
thats idi but not my tuck the second pic is my truck na
Old Jun 3, 2010 | 04:17 PM
zx250's Avatar
zx250
Thanks, I will have to have a much better look at it next time I get a chance. His truck is a 250 and the tires are cambering in a little when backing up. We checked everything out all looked tight and good. He does need a good front end line up. Front tires are wearing the outsides of the tires bad.
Old Jun 3, 2010 | 04:18 PM
joe f350's Avatar
joe f350
swap in a d60 mombean the ttb front axle is norteouis or have tha problem
Old Jun 3, 2010 | 04:26 PM
zx250's Avatar
zx250
Probably will later, now he just wants to get in on the road and safe. He has a brake problem. You have to stand on the brakes to get it to stop. I don't have a vacuum gauge, but just using my finger over the hose, the vacuum seems weak. It has suction, just not very much. Also, it pops out of 4wheel low when any pressure is applied. External linkage all looks good. Any thoughts would be appreciated
Old Jun 3, 2010 | 04:39 PM
  #28
joe f350's Avatar
joe f350
Pensacola Fuel Injection | Worlds #1 Diesel Rebuilder - FORD 6.9L - 7.3L :: VACUUM PUMPS
dose the brake light come on
Old Jun 3, 2010 | 04:41 PM
  #29
zx250's Avatar
zx250
It stays on.
Old Jun 3, 2010 | 04:42 PM
  #30
joe f350's Avatar
joe f350
them its eather low fluid of low vacuim
