Dfuser P0541 AIH Code Eliminator install
Old Jun 2, 2010 | 05:03 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Is this the correct installation? It fits well, given the length and terminal sizes, but the rubber isolator at the bottom connection has me second guessing its usefulness as a ground. Gotta avoid those invisible codes thrown only on the second Tuesday of the week!
Old Jun 2, 2010 | 05:53 PM
megawatt00's Avatar
megawatt00
Yup that is correct I have made quite of few of these up.
Old Jun 2, 2010 | 09:59 PM
renyren's Avatar
renyren
you made that or bought it? If you made it what did you use? I need to do the same thing since I live in CA and we now have the smoke test.
Old Jun 2, 2010 | 10:29 PM
mueckster's Avatar
mueckster
It is a length of wire with a 470 ohm 1/2 watt, or 1 watt (if available), soldered to it with ring terminals, of the proper size, attached to each end.
Old Jun 2, 2010 | 10:53 PM
renyren's Avatar
renyren
do you have a pic of how you put it together? Looks like 4g wire mabye. Csn I make one pretty cheap?
Old Jun 2, 2010 | 11:05 PM
mueckster's Avatar
mueckster
Here is a link to pics of mine in my gallery. 2001 Ford F250 4x4 - AIH Code Eliminator
I used a piece of 14 ga wire.
Old Jun 3, 2010 | 10:25 PM
renyren's Avatar
renyren
I can't tell from the pics where the resistor goes in the line.
Old Jun 3, 2010 | 10:39 PM
mueckster's Avatar
mueckster
I soldered it inline into the stranded wire near the AIH relay. It is covered with heatshrink to protect it and act as a strain relief for the connections. It is pulled out of the wire loom in the second picture to show this.
Old Jun 4, 2010 | 08:02 PM
renyren's Avatar
renyren
Ok thanks I have a California truck is the install the same? Sorry for the dumb questions.
Old Jun 4, 2010 | 08:36 PM
aawlberninf350
It's a Van Gogh
Same install. Actually my truck is a CA model too, but in that pic the CA glow plug box is removed. I'm in Pinole, 10 miles north of Berkeley, and I grew up in Pleasanton so I know where Mountain House is, too! If something falls off while going over the Altamont Pass I'll know where to get parts.
I bought the code eliminator from Dfuser. Good price, the engineering is done, so what the hey. I dunno if I even need this thing; IIRC for the smog test they do check for codes, but I think this P0541 is a soft code with no CEL, so maybe it would pass anyway. I just want to be prepared to pass without any hassles.
Old Jun 4, 2010 | 11:34 PM
renyren's Avatar
renyren
That's funny I grew up in Livermore and I work in el cerrito. Thanks for the help.
Old Jun 5, 2010 | 12:14 AM
Duzitall's Avatar
Duzitall
Does it actually work?
Old Jan 19, 2016 | 02:16 PM
dieseldan444's Avatar
dieseldan444
1/2 watt vs 1 watt
mueckster, What is the difference between a 1/2 and 1 watt resister in this application? Which one is better and why?
Old Jan 19, 2016 | 03:58 PM
Tugly's Avatar
Tugly
Maybe for "just in case". The math works out to just under 1/3 watt.
Old Jan 19, 2016 | 04:37 PM
aawlberninf350
It's a Van Gogh
Since then I learned trucks with a GPCM (and thus all Xs) will throw the P0541 code anyway, even with the code eliminator. Eliminator/resistor works great for GPR equipped trucks, just not GPCM. P0541 does not trigger the CEL so it's a non issue at smog time. So for me the purchase and install was pointless.
And it's useful to see the P0541 (and the B whatever code for the door dinger delete) when trying out a new OBDII adapter or scanning app. Confirms the thing is working.
Live and learn.
