hey guys i have a auto enginuity software on my laptop to
read codes, clear codes, read engine activity , sensors etc.
its not reading cylinders 4 and 7. the truck runs rough when cold
and gets a little smoother warmed up. could this be idm or pcm
problem. also will a 95 idm work on my 96.
thanx for the reply. i have replaced valve cover gaskets, pigtails,glowplugs,uvch,
fuel pump and lines. new fuel filter, oil change and filter. i may try and switch idm's
to see if it helps. please any other help would be appreciated
