Sponsored by: Real Truck
2003 7.3 f-350 engine code errors
Old Jun 2, 2010 | 04:05 AM
rchoatic's Avatar
rchoatic
I have a 2003 Ford F-350 super duty Pick up truck. Over the weeekend the motor started running like dog doo. It runs ok at an idle but as soon as you depress the accelorater it huffs black & white smoke. I did a code read at Auto Zone where these codes came up P-0603 P-1316 P-0478 P-1247 I did replace the fuel filters air cleaner and a engine oil and filter change. Fuel sample seems to be ok? I did not see any water in the fuel /water seperation bowl. Any help to find a cure to these codes would be helpfull. This truck has always ran great and has given minimal engine problems in the past 7 years. At least compared to my 6.0 liter desiel I have in my box truck.
Old Jun 2, 2010 | 02:07 PM
rbaker6336's Avatar
rbaker6336
You will get more info if you post his in the 7.3 forum
https://www.ford-trucks.com/forums/forum31/
Old Jun 2, 2010 | 06:13 PM
F350-6's Avatar
F350-6
Welcome to FTE. Sounds like your problem is just a loose connector plug. Plug it back in and you should be good to go. We call it a UVCH issue for Under Valve Cover Harness.
It's a long thread, but read this https://www.ford-trucks.com/forums/8...ml#post6884198
It's got pictures of the problem, ways to keep it from happening again, recommended maintenance while you're in there, and even a video toward the end showing the "fix".
It strays off topic a bit a couple of times, but it's worth the read.
Old Jun 2, 2010 | 06:14 PM
F350-6's Avatar
F350-6
Double post
stwhite11
Nov 24, 2012 04:49 PM
Jnas860
Oct 28, 2011 08:36 PM
calialx1
Apr 24, 2011 11:12 PM
jennkent5454
1997 - 2003 F150
Nov 11, 2010 02:24 PM
ajaxxx91
Apr 6, 2008 06:17 PM
