There was nothing wrong with the original sensor - don't read a code and just replace the part that's mentioned. The code tells you which sensor is detecting a problem and what that problem is (within the limits of how the system works). You should then diagnose everything that affects that sensor. In your case, check fuel pressure, injector leakage, vacuum leaks, compression, spark plugs & the whole ignition system, ...
Im not sure about the fords... but my past 2 Chebbies had problems like that. After you replace the senors your supposed to disconnect the battery for 30 seconds, and reconnect it.
This resets the computer. Or after 50 (i think) starts it resets itself if the sensor fixed it.
Its a PITA if you do the start thing, I usually just do the battery disconnect.
But then again, Im not sure if Fords are this way, but Im sure they are.
If you still have problems with it... get a truck you won't have to worry much about... a 66 Custom Cab
Now that you mention it, aggie didn't specifically say he had ever CLEARED the codes, so it may just be a leftover. This page and the Haynes manual tell how to clear them.
Ford EFIs need the battery to be unhooked for ~5mins to clear the adaptive strategy from the computer, and they may run rough for ~10 miles afterward while the computer relearns all the sensors, including the new one.
After replacing the sensor, I got the code a couple more times, but after clearing the codes using my code reader, it has been three weeks and it has not thrown me any new codes...hopefully my problem is solved. It is also idling great when I start it up. Thanks for all the help.
