Do I need this?
Redcat, You obviously know fire fighting equipment. Any info you can throw our way is appreciated. There was an offer of technical help from the seller at the auction. He claimed this truck was just "certified" before it was removed from service. It would be blast to suck up a load of water! Around here, I'm sure I would probably need an enviromental impact statement first though! It's been a fun day and I'm going to have a lot of questions. I appreciate all of the information I've picked up on this thread. A thanks to my son who has been a big part of making this all work today. Good to know there is another generation that loves machinery, the smell of fossil fuels, chrome and a little rust.
On that pic of the pump panel, on the left side, about half way down, there appears to be a rating plate. The plate should have the pump manufacturer's name and pump model on it. If you can post this info I can likely supply more info. The valve handles appear to be Hale units but other manufacturers used similar styles.
You might want to try tracing the rig back to the municipality it served. Service records on old rigs are usually pretty extensive and contain a lot of good info. You might even get lucky enough to talk with a mechanic who serviced it.
Unless the regs have changed the certifying process involves the truck pumping water at rated capacity for a set amount of time. If my memory is correct it takes a couple of hours.
Grm61, I am completely ignorant on large trucks. You mention welded wheels. What was the option? I think the FD swapped the front wheels/ tires before it was sold. I can't imagine those unpainted wheels have been on there all these years. The tires look pretty good at a quick glance. I need to take a real close look before I drive it too much.
Krewat, the wipers are the only yhing I have fixed so far. They didn't work and in this part of the country, wipers are very important! I was afraid that they might be vacuum, but I found a missing fuse that got them working. They are 2 speed. I wonder if the electric wipers have been converted. The fuse holder sure looks aftermarket. I have replaced several missing inline fuses. I think someone pulled everything they could find in attempt to disable the gumball light and siren. The only lights I can't get to work are the 2 red lights on standards at the back of the truck.
I supposed someone updated it to electric ones, either that or Ford had electric ones for trucks without air-brakes.
Usually, when a truck has air-brakes, they use air-pressure driven wiper motors, like the Trico-Folberth motors which are cylindrical in shape. If air-brakes weren't installed, they either used vacuum or electric.
Either way, you're all set, so ... again, that's a SHARP looking truck
A couple things that may interest you here. These wheels use a lock ring as part of their assembly and are made for use with tube type tires. If you have tire problems take them to a tire shop that has folks trained to handle them. Any tire has the potential to hurt someone but multi piece wheels greatly enhance the danger.
Pump
On door
Door jamb
I outlined and sharpened the text on some of these because the numbers didn't show up very well. I still have the high-res ones if something is unclear
I've never been around air brakes. Someone told me the system needs to have condensation drained from it. I looked around under the truck, but there seems to 3 or 4 valves that look like condensation drains. A couple of them seemed stuck. The ones I could get open let out a trickle, but there didn't seem to be air behind it. I'm thinking it should be a similar effect as when I drain my shop's air compressors.
Krewat, I'm back to the office tomorrow and I'm going to try and contact the fire dept. and see what kind of info they'll release. I'd love a manual for the truck and a manual on the pump aparatus. I have a lot of questions about switches and ***** like the one labeled "fresnal lights" I can't find anything that operates with that switch. Also, there is a fairly large red light on the far left of the dash that is labeled "compartment light" it is on all the time the truck is in operation.
While I'm asking questions, the automatic transmission seems to shift best if you drive with a heavy foot on the throttle. It seems very slow to upshift if you drive it lightly. Does that seem normal?
Redcat, thanks for the pump info. I'm hoping to get a few of the loose wires, switches and ***** sorted out. I'd never attempt any tire service on this truck. I recognize the budd rims as similar to light truck split rims. I've spent my entire adult life in the automotive repair business. ASE certified master for over 20 years and a shop owner for 15 years. This heavy truck business is very different. I don't have a jack big enough to lift this beast and I probably don't have an impact socket big enough for the lug nuts!
I have a shop building on my property at home I use for tinkering and storage. I've measured it up and I think I can fit the truck in with a little working room to spare. This project has taken on a life of it's own. I really appreciate the info you have all shared.
That is a good set of wheels, they are a 2 piece lock ring design, consisting of the outer flange, and then the lockring...the lockring has a taper that goes down between the flange ring and the bead of the tire.
When things are centered and seated correctly that outer flange ring comes up over the taper and actually holds the lockring into the wheel.
Nothing wrong with them, Just make sure that someone with proper training works on them.
Greg
You are going to need to learn about your brakes...
That truck more than likely has manual slack adjusters, unless someone has changed them to autos at some point.
Brake adjustment is important on these trucks.and needs to be checked regularly.
If you roll under the truck you will see and air can at each wheel.
The rod that comes out of the aircan has a clevis on it, the thing that the clevis hooks to is your slack adjuster... that's where you adjust the brake.
If the nut on the slack adjuster has a collar that is up over the nut they are manual slack adjusters. These take a 9/16 wrench you have to push the collar down to turn the nut.
If the nut has no collar and is exposed they are autos.
Brake adjustment is quick and easy, and important.
Without going through all the book mumbo jumbo...
CHOCK THE WHEELS
Make sure the truck has at least 90psi of air.
RELEASE THE PARKING BRAKE
Before adjusting the brake, push the rod that comes out of the aircan, with your hand, towards the aircan,...brakes that are way out of adjustment will somtimes not return all the way, and appear to be in adjustment .
Turn the nut while watching the brake shoes to make sure you are going the right way.
You want to tighten the brake shoes all the way against the drum untill you can't turn the nut anymore..
Now back the adjusting nut off 1/4 to 1/2 turn, make sure the collar pops back out over the nut.
Shoes need to have at least 1/4 inch of lining to be legal.
These thing need grease to live...
Steering, spring bushings, U joints, S cams, slack adjusters, clutch linkage, clutch arm pivot in the belhousing, throwout bearing, check your front hub oils.
Stop into the DOL and pickup the Commercial Drives Guide,(free) read the Pre-trip section. And the airbrake section.
Those are things you should look for before driving your truck..To much for me to type...
Greg
thats what i do, i could get a cdl and i probally should......but i gross 160k at the grain bins all day when im combining corn and beans, farm truck not for hire.....the commercial state trooper that lives down the road told me farmers dont have to have cdl's.
idk if you could get away with that in washington tho
The trans shifting sounds normal. How many speeds does it have?
The compartment light is to let the chauffeur ( proper name for a fire apparatus driver ) know that one of the compartment doors is open. Open doors can result in lost equipment and do terrible things to parked cars. The switches take a beating and are frequent repair item.
On the wheels, I hope I didn't come across as insulting as it certainly wasn't my intent.
Grm61, thanks for explaining the welded term. I too have seen both styles. Also nice job on the brake adjustment proceedure.
