Sponsored by: Real Truck
Steering stabilizer ?
Old Jun 1, 2010 | 02:08 PM
ontariofarmer's Avatar
ontariofarmer
OK, maybe it's quite obvious, but do you REALLY need one?
A buddy of mine was checking under the front of the truck the other day, and asked me why I don't have one. My answer......"that's the way I bought the truck."
So again, Does it REALLY need to have one, and what are the advantages?
What brand do you recommend?
Old Jun 1, 2010 | 02:41 PM
ChargersFanInCO's Avatar
ChargersFanInCO
they help if you do a lot of off-roading that makes the steering wheel violently fly from side to side...
Old Jun 2, 2010 | 09:29 AM
ontariofarmer
So that's it then? Off road use only?
Old Jun 2, 2010 | 09:43 AM
SBastow's Avatar
SBastow
My truck never came with one
Old Jun 2, 2010 | 09:48 AM
MikeMcCasland's Avatar
MikeMcCasland
The quick answer is, it's not required.
That said, it's a nice feature that gives the truck better driving characteristics. I had to remove mine once after damaging it out at our ranch. It was a 120 mile drive back to Round Rock and you could definitely tell the steering wheel was "easier" to maneuver but not in a good way. I found it less controllable.
The lack of the stabilizer was most noticeable when hitting pot-holes or bumps in the road. When this happened you would experience "bump steer". It effectively means that you didn't have much control over the steering after hitting imperfections in the road.
I think everyone would prefer having a stabilizer but it's by no means required. I find it just gives the truck a better feel when driving, outside of that, no real advantage IMO.
Old Jun 2, 2010 | 09:54 AM
ChargersFanInCO
No, it works in any situation you encounter "bump steer" as mentioned above. There are spots out here I'd like to have one, but not very often. If you turn up the damping on it, it can make it feel like you don't have power steering, but that's bad on the power steering pump, too. Some are fully adjustable, and some just have a factory setting of around 6lbs of damping. They are a must-have on a motorcycle if you like going into sweepers at 120+mph. Otherwise you can develop some serious head shake.
Old Jun 2, 2010 | 09:56 AM
Downriver Thunder's Avatar
Downriver Thunder
Now if you look closely on your steering linkages you may find one. I am not sure what year but they relocated them higher up into the engine compartment. I thought I didn't have one on my 05 but sure enough I looked up higher and there it was. Oh, I wouldn't drive the freeway without one with Michigan roads and the potholes. Helps keep the steering wheel from jumping out of my hands.
Old Jun 2, 2010 | 11:29 AM
dkf's Avatar
dkf
My 04' did not come with a steering stabilizer from the factory. I drove it without the stabilizer for years before I put one on. A steering stabilizer is not a must have but helps smooth the steering jerks out from bumps. A steering stabilizer is not just for offroad use, it helps out greatly on the road as well, lets face it the roads are not getting any better.
After seeing how vulnerable the stock stabilizer on my dads 03' was to being hit I went a different route and fabbed up my own mounts. I used a Napa steering stabilizer along with my custom mounts to mount the stabilizer between the axle and the tie rod. You can't even see it when looking under the truck and theres no way it will get hit like the OE setup. The stabilizer really helps to keep the steering from jerking when hitting a pothole or bump.
Old Jun 2, 2010 | 03:32 PM
brian42's Avatar
brian42
Veteran: Navy
Not required, but it sure does help (especially if you get bigger tires).
Old Jun 2, 2010 | 03:38 PM
grec-o-face's Avatar
grec-o-face
My 02 also DID NOT come with one. I added a dual stabilizer from Rough Country. I don't off-road all that much but I do plow and tow and live in MA. MA is notorious for it's pot-holes.
I noticed a smoother steering ride and less feedback from the wheel.
Was it necessary, no. But it helped & it looks cool.
Old Jun 2, 2010 | 03:44 PM
Flaw's Avatar
Flaw
My truck description is in my signature, and also did not come with one. I figured a 350 dually would, but hmmph... Does anyone know if the mounts are there and I can just add one, or is it something I'm going to have to look aftermarket for? If yes to the aftermarket, any suggestions? Nothing too expensive or hardcore, I RARELY offroad, but the bump steer from the highways here in the Chicago Suburbs are terrible.
Old Jun 2, 2010 | 08:12 PM
Budman1962's Avatar
Budman1962
Here is the one I bought. Defiantly an improvement in steering.
KYB shocks and struts for cars and trucks - Shockwarehouse.com
Old Jun 2, 2010 | 09:14 PM
dkf's Avatar
dkf
The one mounting hoop is on the passenger side of the axle under the spring perch. You will have to buy the OE bracket with u-bolts that mounts the other end of the stabilizer to the steering components. The stock and aftermarket stuff is pretty thin steel thats why I fabbed my own up out of 1/2" and 3/4" steel plate using 1/2" gr 8 bolts. Cheaper than anything you buy and 5 times as strong so I don't have to worry about breaking the mounts. The stock setup also limits you somewhat to the replacement stabilizers you use. Even some "Direct Replacements" have clearence issues as my dad found out the hard way.
Old Jun 3, 2010 | 06:38 AM
ontariofarmer
dkf....got any pics of that bracket?
Old Jun 3, 2010 | 07:39 AM
dkf's Avatar
dkf
The OE one?
