Sponsored by: Real Truck
Steering stabilizer ?
Old Jun 3, 2010 | 08:29 AM
grec-o-face's Avatar
grec-o-face
A pic of my Rough Country set-up...
Old Jun 3, 2010 | 01:46 PM
ontariofarmer's Avatar
ontariofarmer
No, the one you made, dkf
grec.....looks good. Who makes that?
Old Jun 3, 2010 | 03:50 PM
dkf's Avatar
dkf
No, the one you made, dkf.
I'll have to take pics.
That rough country dual setup looks pretty solid, better than others I've seen. Chances are I'd still manage to hit the stabilizer on something.
Old Jun 3, 2010 | 06:15 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
My Rough Country set-up..
Ford Truck Enthusiasts Forums - MoyockPowerstroke's Album: Dual Steering Stabilizer
Old Jun 3, 2010 | 10:28 PM
DAVE67FD's Avatar
DAVE67FD
Just to reiterate, "Steering Stabilizer/s" are "commonly recommended" for larger tires but can be used on stock systems. They will slightly increase your steering effort depending on the type and quantity, hydraulic or gas. They can and do reduce or eliminate steering feedback caused by road imperfections as well as lessen tie rod, ball joint and tire wear. They are cheap insurance IMO.
Old Jun 4, 2010 | 04:00 AM
el boricua's Avatar
el boricua
grec-o-face:
Is your truck stock??? I'm trying to install a set of Rough Country on my truck and I'm having a clearance problem. The center bracket is hitting the crossmember under the engine when I hit a speed bumb or a pothole at the right speed.
I have a clearance about 2 inches between the crossmember and the top of the center bracket.
Any comments welcome
Luis
Old Jun 4, 2010 | 11:38 AM
DAVE67FD's Avatar
DAVE67FD
Do you mean the center bracket mounted to the carrier is hitting the tie-rod bar?
If yes,
In essence it shouldn't although mine was rubbing slightly after my 2.5" level kit and caster shims. The realignment causes the front axle to rotate slightly downward. I shimmed the bracket with a washer between the carrier and the bracket on the lower mount. The axle and tierod shouldn't really move independently unless your tierods are worn.
Or maybe im misinturpiting you. You can also mount the shocks on the underside of the bracket as well. Just swap all the hardware as well as the tie-rod u-bolts.
Old Jun 4, 2010 | 04:02 PM
el boricua's Avatar
el boricua
The center bracket that's installed in the carrier is hitting the crossmember under the engine. The shocks themselves are not touching anything. It doesn't matter if I swap the shocks. The bracket in he center still going to hit the crossmember under the engine.
When you hit a pot hole or a speed bump and the suspension travel up absorbing the impact the center bracket hit the crossmember.
I took a look under the truck and I have a distance of 2 inches between them. My suspension is stock high and mine is an 06 XL. Maybe my springs have loose tension and my front end is lower than it should be. That's what I'm trying to figure out. I know for sure if the truck is lifted or the center bracket is modified there are not going to be any interference, but I would like to verify what's going on before anything else.
Thanks
Luis,
Old Jun 5, 2010 | 08:18 PM
TattooJim's Avatar
TattooJim
My 03 didnt' have one either. When I lifted it and put on 315's I went with Rough Country for the lift and the dual big bore stabilizers. I liked how they wereside by side rather than ganged up on one side. One in compression, one in extension. My truck is a daily driver and drives like a dream. I joke about it being my lifted limo.
Old Jun 6, 2010 | 09:04 AM
grec-o-face
Originally Posted by el boricua
grec-o-face:
Luis
Luis,
My truck is basically stock, but with an added front leaf. It sits about the same height as a truck with X-coded front springs.
I'll take a look under the truck today or Monday and get a pic if I can. You may just have to spin the bracket down a bit (away from the crossmember) to create more clearance -
Old Jun 6, 2010 | 09:08 AM
grec-o-face
Luis,
Is your center bracket similiar to mine? (can you see it in the pic above?)
Is it possible you've got the bracket upside-down?
Old Jun 6, 2010 | 01:59 PM
divedeep1's Avatar
divedeep1
https://www.ford-trucks.com/forums/9...abilizers.html
Old Jun 6, 2010 | 02:03 PM
  #28
divedeep1's Avatar
divedeep1
I spent quite a bit of time shopping around. The above link is my 2 cents on stabilizers w/ a pic.
Old Jun 6, 2010 | 11:41 PM
  #29
bakon's Avatar
bakon
Do any of you guys have the steering stabilzer bar?
Do you leave it installed with these shocks you are adding to the front or remove it?
Old Jun 7, 2010 | 06:45 AM
  #30
D Man's Avatar
D Man
The pro-comp looks like the one I am going to order. Stock height but have oversized mud terrains and can feel the kick back now.
