Need New front Leaves
Old Jun 1, 2010 | 08:33 AM
Redcoat's Avatar
Redcoat
My 1996 f-250 4x4 351 needs new front springs. right now the back sits 1.5" higher than the front. so my question is should I stick with the stock weight rating which I believe is 2775lb, or would I be ok with the heavier duty 3485lb springs? I'd like to get a plow in the future. would the heavier springs lift the truck much higher? would it screw up my alignment? the 3485lb springs are also thicker I believe, which would further add to the lifting. 1980-96 Ford Truck/bronco - Suspension Stock - Stock Front F250,f350
Old Jun 1, 2010 | 09:18 AM
nstueve's Avatar
nstueve
I'd stick with stock and put a pair of air shocks in the front... I know others don't like them and some times the crappy ones break... But, if you get a good pair you can air them up to level the truck off or put extra air in when you have the plow on... Then you can let air out for a better ride when the plow is off... Don't get the cheap air shocks though... spend the $$$$ and they'll last.
Old Jun 2, 2010 | 08:24 AM
Redcoat's Avatar
Redcoat
Thanks. Any more thoughts from people?
Old Jun 5, 2010 | 08:32 PM
broozerthehoundog's Avatar
broozerthehoundog
i put in add a leafs from rough country. raised it up level,but i needed camber adjustment after.
Jim
