6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
best diesel?
Old Jun 1, 2010 | 12:33 AM
big_saxy's Avatar
big_saxy
best diesel?
what nationwide,"chevron, citgo, sinclair, shell........" has the best diesel? Ford says our motors need a min of 45 cetane fuel. Does anyone know what their ratings are?
thank you
Old Jun 1, 2010 | 07:30 AM
senix's Avatar
senix
most are well below the 45 cetane level as there is no set standard. Get your fuel at a truck stop or high volume location is the best advice. When on the road if you have GPS and can program it, do so with truck stop info so you can know when there is one to get fuel.
You can use a cetane booster is about the only thing to do.
Old Jun 1, 2010 | 09:52 AM
R-T0r21on's Avatar
R-T0r21on
BTW- That cetane recommendation/rating of 45 is for cold weather. Naturally higher cetane ##s are better. Just mentioning this because some folks are really getting themselves "wrapped around the axle" over this issue. It's always good to use a good additive, but more for lubricity than cetane. This ULSD is really "dry" in terms of lubrication ability.
Old Jun 1, 2010 | 10:49 AM
ChargersFanInCO's Avatar
ChargersFanInCO
The Diesel Kleen works well in mine. It's a cetane boost, injector conditioner, and lubricity booster all in one. Some day I'll stop by Ford and grab a bottle of theirs, but at $6.00 for 32oz of the Diesel Kleen, I'll probably keep using it. Took away most of my diesel clatter, increased my mileage, and keeps the regens at 300+ miles in-between...Can't beat it imho.
Old Jun 1, 2010 | 11:12 AM
R-T0r21on's Avatar
R-T0r21on
Wow! Where are you getting it for $6.00? I've been using the same stuff. Been buying it at Walmart. I've just started using the XDP additive, just to try it out. No thoughts yet on it. It is only $6.95 for a bottle that treats 500 gal.
Old Jun 1, 2010 | 11:37 AM
ChargersFanInCO
Wal-Mart...Loveland, CO.
Old Jun 1, 2010 | 08:47 PM
Oiler350's Avatar
Oiler350
...I've just started using the XDP additive, just to try it out. No thoughts yet on it. It is only $6.95 for a bottle that treats 500 gal.
Where do you get the XPD? I have yet to see it in any stores around here.
Old Jun 1, 2010 | 08:56 PM
ChargersFanInCO
Fuel Additive Test - Ultra-Low Sulfur Diesel - Diesel Power Magazine
Interesting article on the XPD...Gonna' have to find me some of that...
Old Jun 2, 2010 | 04:07 AM
R-T0r21on's Avatar
R-T0r21on
XDP additive is on line. Extreme Diesel Performance
Old Jun 2, 2010 | 02:50 PM
RuralSurvivalGuide's Avatar
RuralSurvivalGuide
Watch what you buy. XPD is Opti Lube, XDP is Diesel Perf. stuff. I don't know how a quart of XDP can treat 500 Gal
I have been using DK for a few months now, but I did buy a bottle of XDP to see if there is any change. Havent started using it yet though.
Old Jun 3, 2010 | 12:28 AM
powerstroke8994's Avatar
powerstroke8994
There is only one place i know of that uses a high cetane rating enough for a powerstroke. Its a 50 rating. Youll be surprized to know its used by penske truck rental and thats all they run in their trucks plus its like 5 dollars a gallon too. Couldnt believe it but very true though.
Old Jun 3, 2010 | 08:00 AM
ruschejj's Avatar
ruschejj
FYI, the Motorcraft diesel treatment may be more expensive but you only need 4oz. for 25 gallons.
mvedepo
6.7L Power Stroke Diesel
16
Nov 9, 2014 07:36 PM
Diesel 724
30
Nov 3, 2014 07:45 PM
ford7379trucks
Sep 14, 2009 09:40 PM
tex4431
General Diesel Discussion
Mar 1, 2008 12:46 AM
PSNut
Jan 2, 2006 09:56 AM
