Broken Leaf Spring...
Old May 31, 2010 | 10:19 PM
FARM69's Avatar
FARM69
Finally got a break from planting and other activities this weekend and decided to do a little fishing. I was going up a pretty big hill with some monsterous ruts/holes in it when I heard a pretty good metal and metal sound. I just figured it was the suspension doing it's job since the road was extremely rough. I took my foot off the pedal and idle up the rest of the hill in 2nd.
On the return trip down the hill it continued to clank until i heard something metal hit the ground. Long story short, it only rubbed the tire a little bit but doesn't look like it did any real damage.
So, anyone have any good sources for aftermarket rear leaf springs? I'd like to get something a little better than stock.
Old May 31, 2010 | 10:22 PM
1997F-350's Avatar
1997F-350
stock is good....junk yard!!!
Old May 31, 2010 | 10:37 PM
Tom S's Avatar
Tom S
SD springs help the ride. I did them on mine.
Old Jun 1, 2010 | 09:56 PM
Neal 97 250's Avatar
Neal 97 250
X2 on the SD springs. they are a direct replacement. if you iuse the SD shackles you will need to do a little grinding and the bolts thru the frame are a tad bigger.
Excellent mod!
Old Jun 1, 2010 | 10:06 PM
JamesHajek's Avatar
JamesHajek
SD springs are direct and help the ride??
Old Jun 1, 2010 | 11:54 PM
strokin'_tatsch's Avatar
strokin'_tatsch
From what i hear they help the ride. something about different spring rates and all that junk that i know nothing about. LoL
I'd go with the SD springs for sure if they are direct replacements.
Old Jun 1, 2010 | 11:56 PM
desertrat64's Avatar
desertrat64
check out deaver or national springs i think you can get the best bang for your buck a great ride and strong
Old Jun 2, 2010 | 12:00 AM
JamesHajek's Avatar
JamesHajek
I might have to look into that... my bad, im becoming terrible at thread hijacking!
Old Jun 2, 2010 | 12:01 AM
desertrat64
im just tryin to help out
Old Jun 2, 2010 | 05:46 AM
427 fordman's Avatar
427 fordman
Anyone know if the sd springs are as "strong" as an obs rear spring? I know my obs holds a big trailer lots better than dads sd does. His wants to squat a lot more than mine. Just a thought I had. I understand they may ride better but do you sacrifice some towing capacity with them?
Slight hijack here too. Sorry
Old Jun 2, 2010 | 09:35 AM
JamesHajek's Avatar
JamesHajek
I'm guessing you do probably give up a little with the SD springs because in order to have a better ride you can't be as doggone stiff. Just my thinking there, dont actually knwo.
Old Jun 2, 2010 | 03:21 PM
427 fordman
That was kind of my thought too James. Don't actually know for sure either. Mine is a truck and used as one. I'd much rather ride rougher and be able to haul a load better than ride nice and not haul a load as good. Some don't use their truck for towing as much though so I can see the swap for them ( that is if what we are saying is true).
Old Jun 2, 2010 | 03:54 PM
jchosler's Avatar
jchosler
what about upgrading to F350 Springs, I wanna do that for the sake of hauling
