Ignition troubles
Old May 31, 2010 | 07:58 PM
Breaker Breaker 3-3's Avatar
Breaker Breaker 3-3
Question Ignition troubles
Been working on this issue for a while now.
92 f150
4.9L I6
--Rig won't fire up on first crank if it sits more than a few hours. Takes somewhere between 2-7 attempts before it ignites properly.
**Replaced fuel filter, fuel pressure regulator, cleaned injectors, new vacuum lines, wires, rotor+cap, spark plugs. Relay works, etc.
++The rear tank is not functioning. I have heard that there can be an issue with the transfer valve that may be a problem. My two thoughts are that I have a weak/bad in-tank fuel pump on the working tank or that I have to delete the rear tank and plug the lines.
Anybody got an idea? Something i'm not thinking of?
I don't believe it to be the ignition timing --too retarded or forward but i could be incorrect...no way to see the darn notches so no use in using the light on these...
tmcalavy
25
Apr 18, 2012 01:29 AM
Breaker Breaker 3-3
Mar 21, 2012 02:32 AM
Breaker Breaker 3-3
Mar 12, 2012 11:36 PM
Breaker Breaker 3-3
May 9, 2010 06:56 PM
rjaywhit
Oct 7, 2009 09:03 AM
