fuel filter change
Old May 31, 2010 | 05:50 PM
shaw4825's Avatar
shaw4825
fuel filter change
hey guys, i need some help here. I have a 95 F-150 ext cab with dual tanks, im trying to change the fuel filter and messed with it for a few days now and just about over it. I know the ford fuel lines are a pain and i have changed the filter on all my fords but this one is the worst yet. Anybody know of a good tool? i have the scissor type and a metal round one but i cant get in between the filter and coupling. i have dropped the skid plate for the front tank since they thought it was a good idea to put it between the tank and frame rail, but just can get either tool in to release it
Old May 31, 2010 | 06:12 PM
fishforlife2007's Avatar
fishforlife2007
use the scissor tool and put it in/on the line press line and tool in simotaniously. pull line away.
Old May 31, 2010 | 07:35 PM
Volvo92906's Avatar
Volvo92906
sometimes you can get crap in there and I found if you spray some WD40 into where the spring is at it helps.
Old Jun 1, 2010 | 07:01 AM
acom01's Avatar
acom01
i´ve changed mine last saturday. The output side of the filter have good clearence for the tool, but inlet side not. So i loose a little the front fuel tank so it lowers enough to pass the filter with the inlet hose attached under it and get enogh space to work.
obscurity
Jun 6, 2014 11:17 AM
2002exPSD
33
May 16, 2011 11:29 AM
RaceDog
1978 - 1996 Big Bronco
Jan 17, 2010 05:00 PM
spikedog
Aug 28, 2006 10:02 AM
GasMonkey
Jul 31, 2004 06:30 PM
